How to run c program in terminal for imx8mm for Android 10 OS
909件の閲覧回数
Ruban1
How to execute C program in terminal for imx8mm for Android 10 OS. For I2C, UART and SPI communication.
901件の閲覧回数
Bio_TICFSL
Hello Ruban1,
You can compile your C programs with an ARM cross-compiler:
arm-linux-gnueabi-gcc -static -march=armv7-a test.c -o test
Then you can push your compiled binary file to somewhere (don't push it in to the SD card):
adb push test /data/local/tmp/test
