How to run a single core of A53 in iMX 8M nano and what will be the power consumed
2,498 次查看
hariprasanth_sm
imx8m-nano‌
#power mode management
Is it possible to run only a single core of A53 in imx 8m nano and turn off the remaining 3 cores of A53?
We have a critical requirement and for a particular period we want to use only a single core and the power consumption should be optimized.
What is the power required for only a single core in A53 to run?
Thanks in advance
标签 (1)
1 回复
2,428 次查看
gusarambula
Hello Hari Prasanth SM,
You may change the cores frequencies or disable cores from Linux. You may find more details on the i.MX Linux Reference Manual on the CPU Frequency Scaling (CPUFREQ) section. This document is available as part of the BSP Release documentation.
As for power measurements, you may use Application Note 12778 as reference (link below). This application note has a couple of scenarios, but it holds all publicly available power consumption measurements and may serve to get an estimate on what power consumption you can expect on your application.
https://www.nxp.com/docs/en/application-note/AN12778.pdf
My apologies for the inconvenience!
