How to record mono audio using i.MX8M Quad EVK
1,180 次查看
abhishek_kumar2
1,077 次查看
Bio_TICFSL
Hello Abhishek,
Xiaocong is rigth.
1,077 次查看
xiaocong_fu
Hi Abhishek,
The codec in i.MX8MQ evk board is WM8524, which is a DAC and only supports audio playback. If you want to record audio using i.MX8MQ evk board, you need to connect mic via SAI interface and create driver for it.
Xiaocong
