How to implement microsecond timer callback in imx8m mini
Dhevan
  In our linux user space we need to implement 78 microsecond timer callback to read spi data.
  We had implemented the timer callback using timer_create, timer_start api's. But problem is timer doesn't running properly for microsecond until millisecond it's works fine.
  Do you have any recommended solution to implement microsecond timer callback.
Thanks & Regards,
        Vasu
