How to flash SD card without EVK for android
2,639 次查看
shinningball
  1. Currently, I am starting work for flash image to sd card for android 10.
  2. I use the command "uuu_imx_android_flash.bat -f imx8mm -a -e -t sd" to flash image into the Sd card.
  3. I want to know is there any way to flash image to sd card separately without EVK, for example: for linux it could use dd tool.
标记 (2)
2 回复数
2,604 次查看
Rita_Wang
Recommend you to use the UUU tool, it's easy to use.
2,604 次查看
Rita_Wang
The following download methods can be used to write the Android System Image:
• UUU to download all images to the eMMC/SD card.
• fsl-sdcard-partition.sh to download all images to the SD card.
• fastboot_imx_flashall script to download all images to the eMMC/SD storage.
You can see the 5 Programming Images section in our user guide document.
