How to erase whole eMMC?
13,306 次查看
tdoering
we are using the iMX8M Mini EVK and successfully flashed the eMMC using uuu.
Now: How to we completely erase the eMMC again. On u-boot we can do mmc erase 0 <block-count>. This however does only seem to delete the actual linux kernel and images but not the u-boot itself (since its still booting).
Where is that booted u-boot is stored and how to erase it?
Greetings,
Thomas
标签 (1)
1 回复
13,256 次查看
Bio_TICFSL
Hello Thomas,
Open a terminal, and run dd to fill your bootloader partition with zeros:
root:~# dd if=/dev/zero of=/dev/"where is the eMMC"
dd: writing to '/dev/bootloader': No space left on device
8193+0 records in
8192+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 1.1226 s, 3.7 MB/s
Khadas:~# reboot
