How to enable selinux for IMX8QXP?
2,443 次查看
gravity_one
how to enable selinux on linux for imx8qxp?
have document?
use:Linux imx8qxp_mek 4.14.98+g9b4bc51 #1 SMP PREEMPT Fri Aug 6 06:07:59 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
tks,
gravity
标记 (1)
2,432 次查看
BiyongSUN
It is pure yocto question, you should seeking solution in yocto forum if you are using yocto bsp release.
meta-selinux - Layer enabling SELinux support. (yoctoproject.org)
