How to enable MAIN clock and AUDIO PLL clock at same time
2,126件の閲覧回数
zenghuchen
I attached audio pll clock to ctimer0 (CLOCK_AttachClk(kAUDIO_PLL_to_CTIMER0)), but read an offset between ctimer0 and system clock. Output of ctimer0 is around 100 ms later than system clock.
If I attach main clock to ctimer0 (CLOCK_AttachClk(kMAIN_CLK_to_CTIMER0)), I read the same value from ctimer0 and system clock.
And because of the system design, I must use audio pll clock.
So is there a way to enable main clock and audio pll clock at the same time?
Or any other way to read similar value?
Thanks.
ラベル(2)
2,084件の閲覧回数
JorgeCas
Hello, I hope you are doing well.
Could you please share us which processor are you using?
Best regards.
2,081件の閲覧回数
zenghuchen
Sure. I am using RT595.
