How to disable HDMI when board is booted
1,904件の閲覧回数
ivanljubicic
I need to disable hdmi from command line or other way after board is booted. Hdmi is configured in dts files and it is successfully initialized after booting. So I need to disable or shut id down after booting. Reason is regulation of power consumption of board. I have tried some ideas from forum but I have no success. Board is running jocto jethro linux kernel version 3.14.28.
Thanks, regards, Ivan.
ラベル(3)
タグ(4)
1,693件の閲覧回数
Bio_TICFSL
For all the framebuffers you want to disable, you can use video= parameter att bootloader args
 video=mxcfb0:off video=mxcfb1:off video=mxcfb2:off
