How to disable BCH block in i.MX6LL?
keshavakumarb
Dear All,
We are using custom i.MX6ULL board. We are using NAND as a boot media. The NAND used has its own ECC . So I want to disable i.MX6ULL BCH ECC block. Can we disable in through Software? Is there any provision in Linux to disable it?
With Regards,
Keshava Kumar B
fangfang
hello,
Unfortunately, NXP did not test NAND solution without BCH block, also Linuxdrivers has not option to work without BCH.Sorry for the inconvenience may cause.
Have a nice day.
