How to create mtd partitions on NAND
swaraj
How  to create mtd partitions on NAND ,Can anyone help me ?
snan1z
You can check this topic, Mike's reply will help you, he had created ubi volumes with ubimkvol command.
http://imxcommunity.org/group/imx28andimx28evk/forum/topics/imx28-nand-boot-no-init-found
create a ubi volume as <volume_name> that has size of 50MiB
$ ubimkvol  /dev/ubi0 -N <volume_name> -s 50MiB
-m means rest of space
$ ubimkvol  /dev/ubi0 -N <volume_name> -m
Also, attachment at this link may help you
http://imxcommunity.org/forum/topics/imx28-nand-boot?commentId=4103...
JonSzymaniak
The following discussion contains a bunch of info on setting up NAND. It helped me getting NAND with UBIFS running.
swaraj
Thanks for the reply Sinan, Should they be configured while kernel compiling or should we follow any other procedure for that.
Please help me in creating those volumes. As i am stuck at a point.
snan1z
In the past, I dealt with mtd partitioning and according to me it is very hard. Instead of this, ubi volumes may help you ( If you use ubifs ).
