 zdenek_zadera
			zdenek_zadera
		Hello @rampe ,
In NXP Android release, there are created keys/certs in “device/nxp/common/security/” (platform.pk8 and platform.x509.pem). Are you using keys from this location?
The apksinger tool supports signing APKs with keystore file or with the private key file and certificate file separately. Below are some useful links may be helpful:
Zdenek
For example this one had been used
./apksigner sign --append-signature --ks /home/rami/dev/docs/outruntonxp/nxpimx8qmaaos12-platform.keystore /home/username/dev/docs/outruntonxp/wow/build-Outrun_IVI-Android_Qt_6_4_0_Clang_arm64_v8a-Debug/android-build/build/outputs/apk/release/android-build-release-signed.apk
For example one that was tried
./apksigner sign --append-signature --ks /home/username/dev/docs/outruntonxp/nxpimx8qmaaos12-platform.keystore /home/rami/dev/docs/outruntonxp/wow/build-Outrun_IVI-Android_Qt_6_4_0_Clang_arm64_v8a-Debug/android-build/build/outputs/apk/release/android-build-release-signed.apk
openssl accepts only pkcs7, pkcs8 and pkcs12.
What would be the proper keytool command? Following does not seem to work
keytool -keystore NONE -storetype PKCS11 -list
keytool error: java.security.KeyStoreException: PKCS11 not found
For example this had been used
./apksigner sign --append-signature --ks /home/rami/dev/docs/outruntonxp/nxpimx8qmaaos12-platform.keystore /home/uname/dev/docs/outruntonxp/wow/build-Outrun_IVI-Android_Qt_6_4_0_Clang_arm64_v8a-Debug/android-build/build/outputs/apk/release/android-build-release-signed.apk
