How to create correct .keystore for NXP iMX8QM AAOS12?
rampe
Could you hint how to create .keystore properly? I tried using platform.pk8 and .x509.pem files from  nxp/android_build/build/make/target/product/security like below
  • openssl pkcs8 -inform DER -nocrypt -in platform.pk8 -out nxpimx8qmaaos12-platform.key
  • openssl pkcs12 -export -in platform.x509.pem -inkey nxpimx8qmaaos12-platform.key -name nxpimx8qmaaos12-platform -out nxpimx8qmaaos12-platform.pem -password pass:password
  • ../../../../../prebuilts/jdk/jdk11/linux-x86/bin/keytool -importkeystore -destkeystore nxpimx8qmaaos12-platform.keystore -deststorepass password -srckeystore nxpimx8qmaaos12-platform.pem -srcstoretype PKCS12 -srcstorepass password
But when release.apk is signed with jarsigner or apksigner and app is deployed over ADP we get an error in app startup: "The app is not signed with a valid platform signature. The Car API back end cannot work with an unsigned app."
zdenek_zadera
Hello @rampe ,
In NXP Android release, there are created keys/certs in “device/nxp/common/security/” (platform.pk8 and platform.x509.pem). Are you using keys from this location?
The apksinger tool supports signing APKs with keystore file or with the private key file and certificate file separately. Below are some useful links may be helpful:
  1. Convert x509.pem and pk8 file to keystore: https://stackoverflow.com/questions/39657812/how-to-import-x509-pem-pk8-file-into-jks-keystore
  2. apksigner usage: https://developer.android.com/studio/command-line/apksigner
  3. some basic concept about app-signing: https://developer.android.com/studio/publish/app-signing
Zdenek
zdenek_zadera
Hello @rampe ,
I have created internal question to our developers how to proceed correctly with your case.
Zdenek
rampe
For example this one had been used
./apksigner sign --append-signature --ks /home/rami/dev/docs/outruntonxp/nxpimx8qmaaos12-platform.keystore /home/username/dev/docs/outruntonxp/wow/build-Outrun_IVI-Android_Qt_6_4_0_Clang_arm64_v8a-Debug/android-build/build/outputs/apk/release/android-build-release-signed.apk
rampe
For example one that was tried
./apksigner sign --append-signature --ks /home/username/dev/docs/outruntonxp/nxpimx8qmaaos12-platform.keystore /home/rami/dev/docs/outruntonxp/wow/build-Outrun_IVI-Android_Qt_6_4_0_Clang_arm64_v8a-Debug/android-build/build/outputs/apk/release/android-build-release-signed.apk
rampe
..../build-tools/33.0.0/apksigner sign --append-signature --ks .../platform.keystore ..../android-build/build/outputs/apk/release/android-build-release-signed.apk
rampe
build-tools/33.0.0/apksigner sign --append-signature --ks ../platform.keystore ./android-build/build/outputs/apk/release/android-build-release-signed.apk
Zhiming_Liu
Can you try the pkcs11?
rampe
openssl accepts only pkcs7, pkcs8 and pkcs12.
What would be the proper keytool command? Following does not seem to work
keytool -keystore NONE -storetype PKCS11 -list
keytool error: java.security.KeyStoreException: PKCS11 not found
Zhiming_Liu
Hi @rampe
Can you also share the apksigner command you use?
rampe
For example this had been used
./apksigner sign --append-signature --ks /home/rami/dev/docs/outruntonxp/nxpimx8qmaaos12-platform.keystore /home/uname/dev/docs/outruntonxp/wow/build-Outrun_IVI-Android_Qt_6_4_0_Clang_arm64_v8a-Debug/android-build/build/outputs/apk/release/android-build-release-signed.apk
