How to configure the clock source of TPM in iMX8ULP dts?
5,143件の閲覧回数
wendy-liu
Dear all,
    I want to enable TPM4,7,8 on iMX8ULP,but the dts doesn't have device note.
    So, I add TPM8 device node by myself.
    But during probe, the kernel crashes.
    Therefore, how to configure the clock source of TPM?
    log and dts are as below.
5,062件の閲覧回数
AldoG
Thank you for the update, please try by not commenting the assigned-clock-rates & clock-names properties in the tpm node.
Also, please enable the clock to be configured early on ATF:
https://github.com/nxp-imx/imx-atf/blob/lf-6.6.36-2.1.0/plat/imx/imx8ulp/imx8ulp_bl31_setup.c#L68
void bl31_early_platform_setup2(u_register_t arg0, u_register_t arg1,
u_register_t arg2, u_register_t arg3)
static console_t console;
+ /* config the TPM7 clock */
+ mmio_write_32(IMX_CGC1_BASE + 0x908, 0x300);
/* config the TPM5 clock */
mmio_write_32(IMX_PCC3_BASE + 0xd0, 0x92000000);
mmio_write_32(IMX_PCC3_BASE + 0xd0, 0xd2000000);
Please try it and let me know of your results.
Best regards/Saludos,
Aldo.
7 返答(返信)
5,082件の閲覧回数
wendy-liu
Hello!
Here are some updates  I'd like to share with you.
Fortunately, I enable TPM7 CH5(PTF25) successfully, but there is no output waveform.
my device node  :
+tpm7: tpm@29830000 {
+ //compatible = "fsl,imx8ulp-tpm", "fsl,imx7ulp-tpm";
+ compatible = "fsl,imx7ulp-pwm";
+ reg = <0x29830000 0x10000>;
+ //interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
+ clocks = <&pcc4 IMX8ULP_CLK_TPM7>, <&pcc4 IMX8ULP_CLK_TPM7>;
+ assigned-clocks = <&pcc4 IMX8ULP_CLK_TPM7>;
+ assigned-clock-parents = <&cgc1 IMX8ULP_CLK_FROSC_DIV2>;
+ //assigned-clock-rates = <48000000>;
+ //clock-names = "ipg", "per";
+ status = "okay";
+&tpm7 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_tpm7>;
+ #pwm-cells = <3>;
pinctrl_tpm7: tpm7grp {
                fsl,pins = <
                        MX8ULP_PAD_PTF25__TPM7_CH5      0x2
my commands :
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8# echo 5 > export
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8# cd pwm5/
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 400000 > period
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 200000 > duty_cycle
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 1 > enable
5,063件の閲覧回数
AldoG
Aldo.
5,016件の閲覧回数
wendy-liu
Thanks a lot !!! It works well!
5,120件の閲覧回数
AldoG
Could you share the full device tree that you are using?
Also, the node you have added seems to be incomplete that may be part of the reason as to why it does fail to boot correctly.
Aldo.
5,095件の閲覧回数
wendy-liu
ok, I will show it for you.
node TPM7,8 are added by myself.
4,820件の閲覧回数
wendy-liu
I successfully enable pwm signal of TPM7 CH5(PTF25), but there is no output waveform
status = "okay";
&tpm7 {
#pwm-cells = <3>;
fsl,pins = <
4,820件の閲覧回数
wendy-liu
Now, the kernel starts normally.But when I enable PWM channal, it will report an error!
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 100000 > period
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 50000 > duty_cycle
-sh: echo: write error: Timer expired
%3CLINGO-SUB%20id%3D%22lingo-sub-2053556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E6%A7%98%E3%80%81%3C%2FP%3E%3CP%3EiMX8ULP%E3%81%A7TPM4%2C7%2C8%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81dts%E3%81%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81TPM8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E8%87%AA%E5%88%86%E3%81%A7%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E4%B8%AD%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81TPM%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Elog%E3%81%A8dts%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2053556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%3A%20iMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%EF%BC%81%EF%BC%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%3A%20iMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%9B%E3%81%9A%E3%81%AB%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%3Eassigned-clock-rates%20%26amp%3B%20clock-names%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%20TPM%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81ATF%E3%81%AE%E6%97%A9%E3%81%84%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-atf%2Fblob%2Flf-6.6.36-2.1.0%2Fplat%2Fimx%2Fimx8ulp%2Fimx8ulp_bl31_setup.c%23L68%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-atf%2Fblob%2Flf-6.6.36-2.1.0%2Fplat%2Fimx%2Fimx8ulp%2Fimx8ulp_bl31_setup.c%23L68%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3Evoid%20bl31_early_platform_setup2(u_register_t%20arg0%2C%20u_register_t%20arg1%2C%3CBR%20%2F%3Eu_register_t%20arg2%2C%20u_register_t%20arg3)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%E9%9D%99%E7%9A%84console_t%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%2B%20%2F*%20TPM7%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%2B%20mmio_write_32(IMX_CGC1_BASE%20%2B%200x908%E3%80%810x300)%3B%3CBR%20%2F%3E%2B%3C%2FP%3E%0A%3CP%3E%2F*%20TPM5%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3Emmio_write_32(IMX_PCC3_BASE%20%2B%200xd0%E3%80%810x92000000)%3B%3CBR%20%2F%3Emmio_write_32(IMX_PCC3_BASE%20%2B%200xd0%E3%80%810xd2000000)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9C%E3%81%B2%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%2F%E3%82%B5%E3%83%AB%E3%83%89%E3%82%B9%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%AB%E3%83%89%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%3A%20iMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%94%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%B9%B8%E3%81%84%E3%80%81TPM7%20CH5(PTF25)%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E5%87%BA%E5%8A%9B%E6%B3%A2%E5%BD%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2Btpm7%3A%20tpm%4029830000%20%7B%3CBR%20%2F%3E%2B%20%2F%2F%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%2Cimx8ulp-tpm%22%2C%20%22fsl%2Cimx7ulp-tpm%22%3B%3CBR%20%2F%3E%2B%20%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%2Cimx7ulp-pwm%22%3B%3CBR%20%2F%3E%2B%20reg%20%3D%20%26lt%3B0x29830000%200x10000%26gt%3B%3B%3CBR%20%2F%3E%2B%20%2F%2F%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%3CGIC_SPI%2087%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3CBR%20%2F%3E%2B%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%E3%80%81%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3E%2B%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3E%2B%20assigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bcgc1%20IMX8ULP_CLK_FROSC_DIV2%26gt%3B%3B%3CBR%20%2F%3E%2B%20%2F%2F%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20%26lt%3B48000000%26gt%3B%3B%3CBR%20%2F%3E%2B%20%2F%2F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22ipg%22%2C%20%22per%22%3B%3CBR%20%2F%3E%2B%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%2B%7D%3B%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2B%26amp%3Btpm7%20%7B%3CBR%20%2F%3E%2B%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%2B%20%E3%83%94%E3%83%B3ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_tpm7%26gt%3B%3B%3CBR%20%2F%3E%2B%20%23pwm%20%E3%82%BB%E3%83%AB%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%2B%7D%3B%3C%2FP%3E%3CDIV%3E%3CSPAN%3Epinctrl_tpm7%3A%20TPM7GRP%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3EFSL%E3%80%81%E3%83%94%E3%83%B3%20%3D%20%26lt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20MX8ULP_PAD_PTF25__TPM7_CH5%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200x2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26gt%3B%3B%3C%2FDIV%3E%3CDIV%3E%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3C%2FDIV%3E%3CDIV%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%23%20echo%205%20%26gt%3B%20export%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%23%20cd%20pwm5%2F%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20400000%20%26gt%3B%20period%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20200000%20%26gt%3B%20duty_cycle%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%201%20%26gt%3B%20enable%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ETPM7%20CH5(PTF25)%E3%81%AEpwm%E4%BF%A1%E5%8F%B7%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%3CSPAN%3E%E5%87%BA%E5%8A%9B%E6%B3%A2%E5%BD%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ETPM7%3A%20tpm%4029830000%20%7B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22FSL%2CIMX8ULP-TPM%22%2C%20%22FSL%2CIMX7ULP-TPM%22%3B%3CBR%20%2F%3Ecompatible%20%3D%20%22fsl%2Cimx7ulp-pwm%22%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x29830000%200x10000%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%3CGIC_SPI%2087%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%E3%80%81%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3Eassigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bcgc1%20IMX8ULP_CLK_FROSC_DIV2%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%3D%20%26lt%3B48000000%26gt%3B%3B%3CBR%20%2F%3Eclock-names%20%3D%20%22ipg%22%2C%20%22per%22%3B%3CBR%20%2F%3Estatus%20%3D%20%22%E5%A4%A7%E4%B8%88%E5%A4%AB%22%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26amp%3Btpm7%20%7B%3CBR%20%2F%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%E3%83%94%E3%83%B3ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_tpm7%26gt%3B%3B%3CBR%20%2F%3E%23pwm%20%E3%82%BB%E3%83%AB%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epinctrl_tpm7%3A%20tpm7grp%20%7B%3CBR%20%2F%3Efsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3EMX8ULP_PAD_PTF25__TPM7_CH5%200x2%3CBR%20%2F%3E%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20400000%20%26gt%3B%20period%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20200000%20%26gt%3B%20duty_cycle%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%201%20%26gt%3B%20enable%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PWM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20%E3%82%A8%E3%82%B3%E3%83%BC%20100000%20%26gt%3B%E5%91%A8%E6%9C%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20%E3%82%A8%E3%82%B3%E3%83%BC%2050000%20%26gt%3B%20duty_cycle%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20%E3%82%A8%E3%82%B3%E3%83%BC%201%20%26gt%3B%20%E6%9C%89%E5%8A%B9%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-sh%3Aecho%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%9F%E9%99%90%E5%88%87%E3%82%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E8%A6%8B%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8E%E3%83%BC%E3%83%89%20%3CSTRONG%3ETPM7%2C8%3C%2FSTRONG%3E%20%E3%81%AF%E8%87%AA%E5%88%86%E3%81%A7%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20dts%20%E3%81%A7%20TPM%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E5%85%A8%E4%BD%93%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%80%9D%E3%82%8F%E3%82%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%2F%E3%82%B5%E3%83%AB%E3%83%89%E3%82%B9%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%AB%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
