How to check dtb file in imx7.
1,418 次查看
Robbi
Hi team,
          I'm working on imx-7, which has custom build image, Login to root and  I had browse all directories to locate dts/dtb file.
Robbi
1,392 次查看
Zhiming_Liu
Please go to path: /run/media/bootxxxx
Zhiming
1,304 次查看
Robbi
Hi @Zhiming_Liu ,
                         Thanks for the support. I'm facing issue in adding a toolchain in MUCXpressoIDE extension in vs code for Linux(Ubuntu). Please do the needful. And I installed MUCXpressoIDE ver-11.8.0, download SDK for imx-9 but unable to install SDK error(not compatible) again uninstalled IDE, reinstalled new version-24.2.95. , but facing same issue. So which version supports for imx-9 SDK's.
Robbi
1,301 次查看
Zhiming_Liu
Are you using MCUXpresso Installer to manage your toolchain??
Zhiming
