Dear NXP Support team,
I would like to change all the logo and images that are displayed from the beginning of the U-Boot.
When a hdmi monitor is connected to the board, I can see 4 penguins and yocto project image with a progress bar.
I would like to change those images to my own custom images.
Please guide me how I can make those changes.
Please elaborate about the explanation if you can since I'm new to yocto linux imx.
Thank you.
You can refer to the patches realized in the LVDS for the u-boot and kernel, the methods are the almost the same.
i.MX 8MP LVDS seamless display (连续显示) between U-boot and Kernel - NXP Community
Hi,@Rita_Wan
Based on the 8MP_LVDS_patch, I was able to get the display working in U-Boot successfully. But when I added the kernel part, I couldn’t get a seamless transition between U-Boot and the kernel display. The kernel side shows abnormal behavior — the screen flickers — while the display in U-Boot is totally fine.
Could you give me some suggestions on this? What could be causing the issue?
What is the board in your hand? nxp board, or the board you design yourself, have you make your board boot up and display already?
Hi @bych ,
I found the easy way for you to try:
