How to calibrate IMX8MP with 2000MHz clock frequency?
2,003 次查看
abhiroopnray
I am using one custom IMX8MP board. The board is getting successfully calibrated with 800MHz and 1200MHz DDR4 clock frequency. I am trying to calibrate it with 2000MHz but while DDR stress test it is failing as data mis-match between read and write.
I have updated the DDR Stress test tab in the RPA as below:
memory set0x30360054320xFA031
Still it is not working. Can you please let me know how to resolve this issue?
标记 (1)
2 回复数
1,993 次查看
joanxie
DDR4 couldn't support 2000Mhz, only lpddr4 does
1,986 次查看
abhiroopnray
Hi Joanxie,
I am sorry for the typo, but we are using lpddr4.
