How to build android image for imx6 dl?
21300466
i did run fsl-sdcard-partition.sh in Android-imx6dl-SD-DEMO as explained in reference pdf.
But, when i run that, it shows this following message.
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
After finished, i inserted sd card into board slot. And u-boot stopped after showing this error message.
Hit any key to stop autoboot: 0
boota mmc1
boota: bad boot image magic
I changed environment arguments following reference, but the result was same.
What should i fix?
Labels (3)
jimmychan
Please download the Android BSP and Documentation from here
i.MX Software|NXP
