Hello everyone:
I have a development board call marsboard by Embest with imx6 dual core chip.
These day I use the yocto to build the Image but there are no machin-Image support for MarS Board when use command "bitbake xxx-image".
Also,the viv GPU driver had to include,does any document or website can reference?
Hi jerry
recently this board configuration was included in yocto, check
below yocto mailing list patch
Freescale OpenEmbedded/Yocto Layers discussion list ()
I would suggest to post this to meta-fsl-arm mailing list, so that someone familiar with this
board could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
chip
Hi Igor,
Thanks for your answer. Excuse me if I am too much of a newbie to the subject but I don't find the trace of a "board configuration included in Yocto" at the link you provided, are you sure this was included in Yocto because I can't seem to find any trace of it. Thanks a lot in advance.
Kind regards
Ben
Hi Benoit
suggest to check it in meta-fsl-arm mailing list
actually here we support only Freescale reference boards.
