How to authenticate uImage in i.mx6?
1,115 次查看
changbaoma
zImage authenticate  example is explained in AN4581.pdf, but i will use uImage in my product.
I‘m appreciated if someone provide relevant documents or examples.
1,066 次查看
Bio_TICFSL
Hello Changbao,
If you are working with 3.9 or older kernel, Is not supported. now if you are on 3.10 and up kernel, you need to validate the dts then the uboot and zimage , because the is no validation of uImage.
