How to add HDMI resolution to i.MX6 Yocto BSP.
3,104 次查看
satoshishimoda
Senior Contributor I
Hi community,
Our partner want to output WXGA or WUXGA screen via HDMI.
They added the tables for WXGA and WUXGA in drivers/video/mxc/mxc_hdmi.c in L3.10.17-ga BSP similar as vga_mode (line 96).
However, it was not work well when video playback.
Actually, video playback speed was 1.2 times.
So we want to know how to add a new resolution to HDMI display.
Could you let me know correct procedure?
Satoshi Shimoda
标记 (1)
1,831 次查看
joanxie
pls send the detailed modified source code to me, and what uboot command did you use?
1,831 次查看
satoshishimoda
Hi Guanqion Xie,
We modified mxc_hdmi_edid_rebuild_modelist function in drivers/video/mxc/mxc_hdmi.c as following.
fb_destroy_modelist(&hdmi->fbi->modelist);
fb_add_videomode(&vga_mode, &hdmi->fbi->modelist);
fb_add_videomode(&wxga_mode, &hdmi->fbi->modelist);    <- add
fb_add_videomode(&wuxga_mode, &hdmi->fbi->modelist);  <- add
After adding the above code, user will be able to change HDMI resolation to 1280x800 by the following command after Linux BSP boot.
Satoshi Shimoda
1,831 次查看
satoshishimoda
Could you give me a advice about this issue?
