How to active USB ADB function before typec driver porting
bensonliu_tpv
Our product want to design a USB circuit using i.MX8M Mini. The circuit scheme is that USB1 as OTG.
But we use TYPE-C RT1711P instead of ptn5110 (EVK used). Before RT1711P driver porting, how can I active USB ADB function? Currently no ADB function working after plug in USB cable.
Best wishes.
bensonliu_tpv
We found SW Solution to switch USB1 to "device" without typec driver porting temporatily.
This issue can be closed. Thanks
