Hi to all,
I'm trying to activate the resizer hardware of the i.mx6 Dual. I can't understand how to do that.
I'm using kernel 4.9.11 and it's not possible for me to update it. So I'm trying to manipulate driver for my purpose.
I use an external camera connected con CSI0. It works fine. I would to resize from 1920x1080 to 640x360 i.e. 3:1 ratio.
The camera format is YUYV 4:2:2. I suppose I should use postprocessing of the IC, but I'm not sure. I set the IC_PP_RSC register. I set the value 2 into CSI_SENS_CONF_DATA field of the CSI_SENS_CONF register. But nothing happens. I suppose I should activate some IDMAC channels.
Please help me.
Thanks in advance.
I have parked the project for a while, but now I'm retrying to use the hw to resize the image captured from the csi. I can't use gstreamer, but what I want to do is to obtain a resized image directly from the imx. For me it's not clear what to do and I can't find any example. I think it is similar to the rotation. So, I think, I should set the resize coefficient and the downsize coefficient. And then? Should I redirect and enable idmac channel? But which?
Is there a more detailed explanation of the preprocessing and post processing processes?
Hi Denis
one can look at resize example on
resizing\mx6 - ipu-examples - i.MX IPU Examples
Hi.
I saw the example. Interesting
Thanks for your answer but in the example it is necessary to open a device (mxc_cpu) and send to it the raw image.
What I would to do is to connect CSI to IC, resize the image, and then read the image.
there are also example in baremetal sdk (1.1.0_iMX6_Platform_SDK.zip) available on
Description can be found in sect.18.10.4 Image resizing example iMX6_Firmware_Guide.pdf
included in package.
Gstreamer examples : sect. 7.3.15 Video conversion Linux Guide included in
Linux 4.19.35_1.1.0 Documentation
I try this function:
void ipu_ic_init_pp (struct ipu_soc *ipu, uint32_t original_width,
uint32_t original_height,
uint32_t destination_width,
uint32_t destination_height,
uint32_t pixel_format)
ipu_channel_params_t params;
params.mem_pp_mem.outv_resize_ratio = 0;
params.mem_pp_mem.outh_resize_ratio = 0;
params.mem_pp_mem.in_height = original_height;
params.mem_pp_mem.out_height = destination_height;
params.mem_pp_mem.in_width = original_width;
params.mem_pp_mem.out_width = destination_width;
params.mem_pp_mem.in_pixel_fmt = pixel_format;
params.mem_pp_mem.out_pixel_fmt = pixel_format;
params.mem_pp_mem.graphics_combine_en = false;
params.mem_pp_mem.global_alpha_en = false;
params.mem_pp_mem.key_color_en = false;
_ipu_ic_init_pp (ipu, ¶ms);
But nothing changed.
