Hi Fredrik
in general Image Converter sub-module is quite slow, it may take up to 4clocks/pixel
processing. One can try to play with using real time channels, marking IPU accesses
with an AXI ID to bypass the PL301’s arbitration. Please check IMX6DQRM
sect.44.5.1.2 Real time channel mode,
36.4.8 GPR (IOMUXC_GPR7),
37.4.2.4.1 Handling real time channels,
Table 37-14. Channel Parameters Memory
AXI Id field
