How to access to low-level drivers from Android
1,705 次查看
artemdmitriev
Hello!
I am studuying  how to develop low-level drivers for android on iMX6 based platform. How can i control PWM, CAN, SPI etc from android? Can i do it from android application or i must rewrite android sources?  Where i must read data, received in interrupts? Give me advice, where to read full information about interaction between kernel drivers and android/android applications, please.
Thank you!
标签 (5)
1,476 次查看
Hi Artem
as android is based on linux, seems approach may be used the same,
for example below link explaining usage memtool in android
https://github.com/rabeeh/android-imx6-kitkat/blob/master/platform/external/linux-test.git/0400-ENGR...
