How to Access Internal SATA PHY Registers Through i.MX6 SATA Registers
1,167件の閲覧回数
JithCR
Is it possible to get the procedure for accessing SATA PHY registers(16Bit) through SATA registers (PHY Control Register SATA_P0PHYCR) PHY Status Register (SATA_P0PHYSR))
816件の閲覧回数
Hi Jith
the detailed hardware operation of SATA is described in the Synopsys DesignWare
Cores SATA AHCI documentation, named SATA_Data_Book.pdf.
https://www.synopsys.com/dw/doc.php/ds/c/dwc_sata_csds.pdf
examples of usage one can find in SDK example sata.c
i.MX 6Series Platform SDK : Bare-metal SDK
