How regulator voltages are set
2,989 次查看
ioteng
We are currently trying to set the  PMIC(pfuze3000 A3) output voltage to 1.375V.  We tried setting the registers in u-boot but it gets overridden by the kernel during bootup. Currently, the only other method we know is by setting the operating-points tuple in the device tree. Is this correct method?
Leonardo
标签 (4)
标记 (4)
1 回复
2,914 次查看
Hi Leonardo
for linux regulator usage one can look at sect.2.5.2 PMIC PF Regulator
attached Linux Manual.
