How do I avoid flashing code at every deploy and deploy to RAM
已解决
跳至解决方案
2,245 次查看
shahmanishj
Senior Contributor II
It takes a long time to program and verify at each deploy. We want to speed up deploy process. All our IDEs so far allowed to deploy image to RAM. Is is possible with MCUxpresso?
标记 (1)
1 解答
2,217 次查看
jingpan
Hi @shahmanishj ,
Then you have to deploy your project to SDRAM. Before debug, you must use a script to initialize SDRAM. Please refer to https://community.nxp.com/t5/i-MX-RT/RT1060-SDRAM-Initialization-Script/m-p/1309789
jing
在原帖中查看解决方案
3 回复数
2,227 次查看
jingpan
Hi @shahmanishj ,
Yes, of course. Check properties->settings->Managed Linker Script->Link application to RAM.
Jing
2,220 次查看
shahmanishj
Thanks for your prompt reply.
I get following error
2,218 次查看
jingpan
Hi @shahmanishj ,
jing
