How do I avoid flashing code at every deploy and deploy to RAM
2,248件の閲覧回数
shahmanishj
Senior Contributor II
It takes a long time to program and verify at each deploy. We want to speed up deploy process. All our IDEs so far allowed to deploy image to RAM. Is is possible with MCUxpresso?
タグ(1)
2,220件の閲覧回数
jingpan
Hi @shahmanishj ,
Then you have to deploy your project to SDRAM. Before debug, you must use a script to initialize SDRAM. Please refer to https://community.nxp.com/t5/i-MX-RT/RT1060-SDRAM-Initialization-Script/m-p/1309789
jing
3 返答(返信)
2,230件の閲覧回数
jingpan
Hi @shahmanishj ,
Yes, of course. Check properties->settings->Managed Linker Script->Link application to RAM.
Jing
2,223件の閲覧回数
shahmanishj
Thanks for your prompt reply.
I get following error
2,221件の閲覧回数
jingpan
Hi @shahmanishj ,
jing
