How can write GPIO function code for freescale i.mx6 ,0 or 1 can be designed to control the command line?
ソリューションへジャンプ
2,726件の閲覧回数
陳冠儒
hi,all:
Consult all,I want to design a GPIO function code for freescale i.mx6,0 or 1 can be designed to control command  line.
(中譯: 我想要設計一個能在命令列輸入指令的 GPIO function code,主要是要能夠在命令列區下指令控制GPIO 能動作為1或0)
Please help me for everyone,thanks.
ラベル(4)
2,354件の閲覧回数
Hi 陳 冠儒
it may be recommended to check links below
https://community.freescale.com/docs/DOC-1459
Definitive GPIO guide - Studio Kousagi Wiki
http://falsinsoft.blogspot.com/2012/11/access-gpio-from-linux-user-space.html
Working with GPIO on the Wandboard and Writing an Android Driver for GPIO Interrupts | Using Android...
3 返答(返信)
2,355件の閲覧回数
Hi 陳 冠儒
2,354件の閲覧回数
陳冠儒
hi,igorpadykov:
After read the website,I still do not know how to write GPIO control code for send command to control 0 or 1.
Please help me,thanks.
(中譯:去閱讀完您提供的網站後,我還是不知道如何去撰寫可以在命令列下,下達命令去做GPIO control 的程式碼。
         請幫忙我一下,感謝您。
2,354件の閲覧回数
陳冠儒
hi,igorpadykov:
Thank u answer.
I read the website,If there is a problem,I go to ask you.
thanks for your help.
(中譯:感謝您的回答,我去閱讀您提供的網站後,若是還有問題,我再請教於您。
         感謝您的幫忙。
