How can enable uart-2 in ATF on i.mx8m mini platform, and boot Customer OS bin file
1,143 次查看
LeonGu
How can enable uart-2 in ATF on i.mx8m mini platform, and boot Customer OS .bin file.
1,137 次查看
igorpadykov
Hi Xudong
proper uart2 rdc permissions can be provided in atf codes (configuration is done on lines 312 - 314)
https://source.codeaurora.org/external/imx/imx-atf/tree/plat/imx/imx8mm/imx8mm_bl31_setup.c?h=lf-5.4...
