How can I test JB4.3 “webrtc(web real-time communication)” function in i.MX6Q Sabre SD?
14,495 次查看
yangruihero
Dear:
I have found that JB4.3 has added new "webrtc" feature in "i.MX6 android_jb4.3_1.0.0 Android Release Notes", could you please provide some detailed information about this function?
How can I test JB4.3 "webrtc(Web real-time communication)" function in i.MX6Q Sabre-SD?
Thank you very much!
标签 (2)
13,649 次查看
max_tsai
hi,
According to the log, that seems to be related with chromium browser. These is a similar open issue on chromium.
http://code.google.com/p/chromium/issues/detail?id=362348
Max
16 回复数
13,649 次查看
norisugi
I tested the WebRTC using the Chrome with UVC USB Camera.
Then the browser crash occurred.
It seems that audio driver crash.
I attach the adb log.
Could you check it ?
13,650 次查看
max_tsai
hi,
Max
13,649 次查看
norisugi
Currently I can't judge whether this issue is due to the browser or not.
I got the another adb log.
Could you check the attached file ?
13,649 次查看
max_tsai
Your attached log also looks similar as Issue 362348 - chromium - [Android-WebRTC] Crash in accessing WebRTC page with external USB camera -...
I/DEBUG   ( 2358): backtrace:
I/DEBUG   ( 2358):     #00  pc 0001e684  /system/lib/libc.so
I/DEBUG   ( 2358):     #01  pc 0001c550  /system/lib/libc.so (abort+4)
I/DEBUG   ( 2358):     #02  pc 000121f1  /system/lib/libc.so
I/DEBUG   ( 2358):     #03  pc 00011701  /system/lib/libc.so (__assert2+20)
I/DEBUG   ( 2358):     #04  pc 01bf1649  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #05  pc 01bf173d  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #06  pc 01bf3c6b  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #07  pc 01aad261  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #08  pc 01a9a74b  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #09  pc 01ab2d9b  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #10  pc 01aab13d  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #11  pc 00b82601  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
I/DEBUG   ( 2358):     #12  pc 00b7fe33  /data/app-lib/org.chromium.chrome.shell-1/libchromeshell.so
Max
13,649 次查看
norisugi
Thank you for your information.
My issue has been fixed by the workaround of the WebRTC project.
Many thanks !
13,649 次查看
EricNelson
Senior Contributor II
Hi Nori,
Do you have a reference to the fix?
13,649 次查看
norisugi
13,649 次查看
EricNelson
Thanks Nori.
13,649 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
MaxTsai can you continue with the  follow up?
13,649 次查看
YixingKong
Senior Contributor IV
Rui
Since there is no reply from you, I am closing the DI. If your issue still exists please come here again and reopen the DI.
Yixing
13,649 次查看
YixingKong
Rui, are you ok to close the DI?
Yixing
13,649 次查看
EricNelson
Actually, this doesn't answer the question, it just brings up another:
How do you install Chrome?
(Chrome isn't a part of the stock build)
We've tested WebRTC successfully in the 4.2-beta using the Mozilla Fennec browser
as described here:
     http://boundarydevices.com/second-release-jellybean-4-3-beta-mx6/
13,649 次查看
max_tsai
Sure, you can use firefox browser for Android instead of Chrome. That blog shows how to use Firefox also.
Since Mozilla starts to support webRTC since Firefox 24, you can install lastest Firefox for Android without Aurora.
Then you test by Mozilla gUM test page as you describes in your http://boundarydevices.com/second-release-jellybean-4-3-beta-mx6/
Or you can test by palava.tv
13,649 次查看
EricNelson
:smileyhappy: And the https://palava.tv/test URL is much easier to type!
13,649 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
MaxTsai please continue with the follow up.
