How can I boot from external SD card of MCIMX93EVK (I.mx93 evk)?
已解决
跳至解决方案
2,654 次查看
gyyang
I am trying to boot from external SD card of I.mx93 EVK.
I made a SD card according to the i.mx linux user manual 4.3.2.
      sudo dd if=imx-image-multimedia-imx93evk.wic of=/dev/mmcblk0 bs=1M && sync
I changed the boot mode switch (SW1301) to 0010 for SD card boot. And installed sd card and turn on.
But nothing happened. I could see no debug message from debug port.
Is there anyone who can download image to external SD card and boot correctly?
Thanks.
1 解答
2,616 次查看
Harvey021
That is correct.
Harvey
在原帖中查看解决方案
4 回复数
2,629 次查看
Harvey021
The BMODE should be as SW1301-1: 0, SW1301-2: 1, SW1301-3: 0, SW1301-4: 0 for SD Card boot instead of 0010.
Harvey
2,621 次查看
gyyang
Thank you for your reply!
I think attached is the right setting for SD card boot, isn't it?
2,617 次查看
Harvey021
That is correct.
Harvey
2,542 次查看
gyyang
Thanks.
I found that my board has A0 silicon that is not supported by latest release.
