How To Modify Ethernet RGMII in Cortex-M4
1,913 次查看
waynechung2
I found the Ethernet driver example in mcuxpresso_sdk_2.9.
Dose the RGMII controller write in "fsl_enet.c" ?
If we change other Ethernet transceiver, how could we modify it ?
Thanks.
Wayne.
2 回复数
1,884 次查看
Dhruvit
Hi @waynechung2,
From the last question, I understood that you are looking to change the Ethernet PHY IC. Please confirm.
Dhruvit.
1,904 次查看
waynechung2
Hi NXP,
Any update about this issue.
Thanks.
Wayne.
