Hotplug PCIe endpoint
1,876 次查看
niklasmolin
Senior Contributor I
Hi.
We have an i.MX6D and trying to use the PCI to connect to a FPGA.
We load the FPGA and rescan the PCI and the FPGA shows up.
We initialize the driver etc. and can communicate with registers inside the FPGA.
After that we try to change bitfile in the FPGA and then re-establish the PCI connection.
It shows up again when doing lspci and when trying to accessing the FPGA register via the driver, the whole CPU hangs, when trying to access the memory area assigned for the PCI bus.
We have tried to use the remove under /sys/bus/pci..., remove the driver (and initialize it again when reloading FPGA, to make sure we get a new memory location).
Any suggestions what steps we need to take to "hotplug" an endpoint to the PCI bus?
标签 (2)
1,732 次查看
weidong_sun
Hello Niklas,
     PCIe interface on i.MX6 doesn't support Hotplug.
TIC    Weidong
