Himax HX83192 Touchcontroller Linux Driver
6,637件の閲覧回数
cbl
I want to control Himax HX83192 touchcontroller with iMX8QM.
But I couldn't find the driver for the HX83192 IC.
Could you please share a driver and dts sample?
Best regards.
3 返答(返信)
5,902件の閲覧回数
yasan
Hello, I'm looking for a Touch panel that incorporates Himax HX83192 touchcontroller. Could you please tell me which panel do you use?
6,622件の閲覧回数
Bio_TICFSL
Hello efecancebel,
If you don't found the driver in the BSP then you need to ported or you need to write it.The himax.com.tw site doesn't even recognize the expression HX83192. So no wonder a driver search for a nonexistent device turns up nothing.
6,611件の閲覧回数
cbl
Hello @Bio_TICFSL,
I want to add the driver externally, but as I said before, I cannot find the driver for the HX83192.
Below is the link that the HX83192 IC is on Himax's site.
Himax Official Site HX83192 Link: https://www.himax.com.tw/products/display-drivers/consumer-electronic-products/
Best regards.
