Harpoon & eMMC
Harpoon & eMMC
1,823件の閲覧回数
francoislion
I am currently evaluating the HARPOON technology on iMX8MN (evaluation) and IMX93(possible target).
It seems that Linux in HARPOON mode cannot use eMMC (see Known issues HRPN-245 in the HARPOON user guide). This is a problem because it is fine to use SD card for evaluation, but not for our products.
What is the reason, and is it planned to fix this issue?
François Lion
2 返答(返信)
1,788件の閲覧回数
AldoG
This is because the 2nd OS uses the pins for the eMMC (SDHC3 on device tree).
I do not think this may be an issue that could not be fixed, but unfortunately for the EVK it may not.
Best regards/Saludos,
Aldo.
1,757件の閲覧回数
francoislion
Thank you for the answer. I am happy to hear that it should be easy to fix...
Still, I don't get what you mean by "the 2nd OS uses the pins for the eMMC", I probably should have to look in details at the real time sample source code.
François Lion
