- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Dear Harpoon Experts,
From the UG10170 - Harpoon User's Guide, I learn that there's a possibility to configure the number of CPU core(s) allocated to the RTOS :
For a multicore (SMP) cell, two cores can be used. For instance, on i.MX 8M:
.cpus = {
0b1100,
I would like to know if it is feasible to allocate up to 3 cores to the RTOS ? And what file(s) among the below should I modify in the case of iMX8M Nano EVK and FreeRTOS, please ?
• configs/arm64/imx{8m*,93,95}-harpoon-freertos.c for the cell configuration of the FreeRTOS
hello_world and rt_latency use case
• configs/arm64/imx{8m*,93,95}-harpoon-zephyr.c for the cell configuration of the Zephyr
• configs/arm64/imx{8m*,93}-harpoon-freertos-audio.c for the cell configuration of the
FreeRTOS audio use case
• configs/arm64/imx{8m*,93}-harpoon-zephyr-audio.c for the cell configuration of the Zephyr
audio use case
• configs/arm64/imx{8m*,93}-harpoon-freertos-avb.c for the cell configuration of the FreeRTOS
audio (AVB) use case
• configs/arm64/imx{8m*,93}-harpoon-zephyr-avb.c for the cell configuration of the Zephyr audio
(AVB) use case
• configs/arm64/imx{8m*,93}-harpoon-freertos-industrial.c for the cell configuration of the
FreeRTOS industrial use case
• configs/arm64/imx{8m*,93}-harpoon-zephyr-industrial.c for the cell configuration of the
Zephyr industrial use case
• configs/arm64/imx{8m*,93}-harpoon-freertos-virtio.c for the cell configuration of the
FreeRTOS Virtio Networking use case
Thanks in advance and best regards,
Khang
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi khang:
I would suggest you modify the CONFIG_INMATE_CORE_BITMAP in configs/arm64/imx8mn-harpoon-freertos.c
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Where to download the source file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @3517884267
I would suggest you check the Harpoon user's guider, you can get the source code from github.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
configs/arm64/imx{8m*,93,95}-harpoon-freertos.c 源文件在哪下载
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It is possible to configure the number of core to '3' to allocate to the RTOS.
You need to change here
45 .cpus = {
46 #if defined(SINGLE_CORE)
47 0x1,
48 #elif defined(THREE_CORES)
49 0x7,
50 #else
51 0x3,
52 #endif
53 },
Since we don't test this scenario on our side before, you need to do more tests, and let us know if you come across some issues.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @danielchen,
Thanks for your answer. Can you please tell which file should I apply the modification ?
Searching within imx-jailhouse, I only found :
$ ag ".cpus =" | grep imx8mn
configs/arm64/imx8mn-lk.c:177: .cpus = {
configs/arm64/imx8mn.c:65: .cpus = {
configs/arm64/imx8mn-linux-demo.c:42: .cpus = {
configs/arm64/imx8mn-inmate-demo.c:45: .cpus = {
configs/arm64/imx8mn-root-lk.c:66: .cpus = {
But nothing relevant to RTOS.
K.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi khang:
