HOW TO Change HDMI Display Output Refresh Rate IMX.8??
hhami_2040
Hello All,,
We have an iMX8 QM(Apalis Module) and Ixora carrier board(Toradex Company).
We want to display a FullHD 1920-1080-30 htz but currently it works as 1920-1080-60!!
I just wanna ask how to Change Refresh rate??
Thank you very much.
Zhiming_Liu
Hello @hhami_2040
Are you using weston ? If yes, you can try to change the weston.ini refering this page:https://manpages.ubuntu.com/manpages/trusty/man5/weston.ini.5.html
[output]
mode=1920x1080@30
hhami_2040
Hello @Zhiming_Liu
Thank you for your answer!!
Can you guide me ,how to change HDMI Display Resoulation??
For example :1280*720@30
I'm using Wayland/Weston!!
Zhiming_Liu
Hi @hhami_2040
Yes, you can try to config like that
