HDMI on IMX53 QSB-R
HDMI on IMX53 QSB-R
2,785 次查看
VuPhung
I have tested HDMI on IMX53 QSB-R, it only display the image, there's no sound. I found that default sound output is connected to SGT15000 (audio codec chipset).
Where should I modify the source code to set default sound output is connected to HDMI?
Vu Phung
2,354 次查看
daiane_angolini
Are you using linux? (alsa?)
Please, take a look on this document HDMI audio setting
And please, let me know if there is anything I can improve my doc.
2,353 次查看
VuPhung
Dear Daiane,
Thanks for your support.
I tested HDMI with Android 2.3-Adeneo version 4.3; Please help me, how can I set up default audio output to HDMI instead of SGTL5000?
Vu Phung
2,353 次查看
daiane_angolini
I have never tried this on Android. So, I´m not sure it will work.
Could you, please, try the how-to on the document and let me know the result?
