HDMI Module, iMx6
HDMI Module, iMx6
johnballance
Hi.. Can anyone confirm whether a fully initialised HDMI module is all that required initialising to produce a raster on a display?  If not, which is the minimum subset of modules (or functions...) that also need initialising before something can be detected on the display?.. nothing displayed in that display of course, just a blank synchronised display..
Many thanks
John
jamesbone
Basically we can said that three different modules need to be initialized  the IOMUX for the pads to be used in the HDMI, the DMA / Memory Controller , and the PLL to provide the clock signal for the module, you can find a HDMI driver in bareboard in the Platform SDK that you can download from the following web page:
https://www.freescale.com/webapp/Download?colCode=i.MX6_PLATFORM_SDK
saludos
