HABv4 on imx6ull
1,522件の閲覧回数
GrDK
I burn a signed u-boot-dtb.imx, and prog the fuse, when check the hab events, it occurs err like this. What could I do for it?
=> hab_status
Secure boot disabled
HAB Configuration: 0xf0, HAB State: 0x66
--------- HAB Event 1 -----------------
event data:
0xdb 0x00 0x14 0x42 0x69 0x0a 0xc0 0x00
0xca 0x00 0x0c 0x00 0x01 0xc5 0x1d 0x00
0x00 0x00 0x07 0xe4
STS = HAB_WARNING (0x69)
RSN = HAB_UNS_ENGINE (0x0A)
CTX = HAB_CTX_COMMAND (0xC0)
ENG = HAB_ENG_ANY (0x00)
--------- HAB Event 2 -----------------
event data:
0xdb 0x00 0x1c 0x42 0x69 0x0a 0xc0 0x00
0xca 0x00 0x14 0x00 0x02 0xc5 0x1d 0x00
0x00 0x00 0x0d 0x3c 0x87 0x7f 0xf4 0x00
0x00 0x08 0x2c 0x00
ラベル(4)
1,490件の閲覧回数
JorgeCas
This processor does not have CAAM, I suggest you try with a different engine:
[Header]
Version = 4.2
Hash Algorithm = sha256
Engine Configuration = 0
Certificate Format = X509
Signature Format = CMS
Engine = SW
Best regards.
5 返答(返信)
1,491件の閲覧回数
JorgeCas
[Header]
Version = 4.2
Engine = SW
Best regards.
1,479件の閲覧回数
GrDK
Hi JorgeCas,
thanks for your reply, and I finally reach at
No HAB Events Found!
But lately when I boot the device, it occurs
Authenticate image from DDR location 0x80800000...
bad magic magic=0x0 length=0x00 version=0x0
bad length magic=0x0 length=0x00 version=0x0
bad version magic=0x0 length=0x00 version=0x0
Error: Invalid IVT structure
Allowed IVT structure:
IVT HDR = 0x4X2000D1
IVT ENTRY = 0xXXXXXXXX
IVT RSV1 = 0x0
IVT DCD = 0x0
IVT BOOT_DATA = 0xXXXXXXXX
IVT SELF = 0xXXXXXXXX
IVT CSF = 0xXXXXXXXX
IVT RSV2 = 0x0
Authenticate zImage Fail, Please check
I do not make any config to authenticate zImage, could u please give me a help?
1,459件の閲覧回数
JorgeCas
This error is because authenticate image code failed, you can refer to the application note to check if your steps are correct.
You can also refer to the next links:
https://community.nxp.com/t5/i-MX-Processors/Secure-boot-imx6-Invalid-IVT-structure/td-p/1618944
https://www.ezurio.com/documentation/high-assurance-boot-hab-for-dummies
Best regards.
1,474件の閲覧回数
GrDK
And I found that, we use mfgtools to update uboot, zImage and ..., once enable HAB, mfgtool could not work.
1,519件の閲覧回数
GrDK
Here is my csf_uboot.txt,
[Header]
Version = 4.2
Engine = CAAM
[Install SRK]
# Index of the key location in the SRK table to be installed
File = "../crts/SRK_1_2_3_4_table.bin"
Source index = 0
[Install CSFK]
# Key used to authenticate the CSF data
File = "../crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate CSF]
[Install Key]
# Key slot index used to authenticate the key to be installed
Verification index = 0
# Target key slot in HAB key store where key will be installed
Target Index = 2
# Key to install
File= "../crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate Data]
# Key slot index used to authenticate the image data
Verification index = 2
# Authenticate Start Address, Offset, Length and file
Blocks = 0x877ff400 0x00000000 0x00082c00 "u-boot-dtb.imx"
%3CLINGO-SUB%20id%3D%22lingo-sub-2335788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx6ull%20%E3%81%AE%20HABv4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2335788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%BD%B2%E5%90%8D%E6%B8%88%E3%81%BF%E3%81%AE%20u-boot-dtb.imx%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81hab%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3D%26gt%3B%20hab_status%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3EHAB%20%E6%A7%8B%E6%88%90%EF%BC%9A0xf0%E3%80%81HAB%20%E7%8A%B6%E6%85%8B%EF%BC%9A0x66%3C%2FP%3E%3CP%3E---------%20HAB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%881%20-----------------%3CBR%20%2F%3E%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%3A%3CBR%20%2F%3E%200xdb%200x00%200x14%200x42%200x69%200x0a%200xc0%200x00%3CBR%20%2F%3E%200xca%200x00%200x0c%200x00%200x01%200xc5%200x1d%200x00%3CBR%20%2F%3E%200x00%200x00%200x07%200xe4%3C%2FP%3E%3CP%3ESTS%20%3D%20HAB_WARNING%20(0x69)%3CBR%20%2F%3E%20RSN%20%3D%20HAB_UNS_ENGINE%20(0x0A)%3CBR%20%2F%3E%20CTX%20%3D%20HAB_CTX_COMMAND%20(0xC0)%3CBR%20%2F%3E%20ENG%20%3D%20HAB_ENG_ANY%20(0x00)%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E---------%20HAB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%882%20-----------------%3CBR%20%2F%3E%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%3A%3CBR%20%2F%3E%200xdb%200x00%200x1c%200x42%200x69%200x0a%200xc0%200x00%3CBR%20%2F%3E%200xca%200x00%200x14%200x00%200x02%200xc5%200x1d%200x00%3CBR%20%2F%3E%200x00%200x00%200x0d%200x3c%200x87%200x7f%200xf4%200x00%3CBR%20%2F%3E%200x00%200x08%200x2c%200x00%3C%2FP%3E%3CP%3ESTS%20%3D%20HAB_WARNING%20(0x69)%3CBR%20%2F%3E%20RSN%20%3D%20HAB_UNS_ENGINE%20(0x0A)%3CBR%20%2F%3E%20CTX%20%3D%20HAB_CTX_COMMAND%20(0xC0)%3CBR%20%2F%3E%20ENG%20%3D%20HAB_ENG_ANY%20(0x00)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2335788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%85%A8%E3%81%A6%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6UL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESecurity%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HABv4%20on%20imx6ull%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81uboot%E3%80%81zImage%E3%81%AA%E3%81%A9%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABmfgtools%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81HAB%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8mfgtools%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HABv4%20on%20imx6ull%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81JorgeCas%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%81%A4%E3%81%84%E3%81%AB%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3EHAB%E6%A7%8B%E6%88%90%3A%200xf0%E3%80%81HAB%E7%8A%B6%E6%85%8B%3A%200x66%3CBR%20%2F%3E%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%81%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E6%9C%80%E8%BF%91%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3EDDR%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x80800000%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%8D%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%82%AA%E3%81%84%E9%AD%94%E6%B3%95%20magic%3D0x0%20length%3D0x00%20version%3D0x0%3CBR%20%2F%3E%E4%B8%8D%E6%AD%A3%E3%81%AA%E9%95%B7%E3%81%95%E3%83%9E%E3%82%B8%E3%83%83%E3%82%AF%3D0x0%20%E9%95%B7%E3%81%95%3D0x00%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D0x0%3CBR%20%2F%3E%E4%B8%8D%E6%AD%A3%E3%81%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20magic%3D0x0%20length%3D0x00%20version%3D0x0%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E7%84%A1%E5%8A%B9%E3%81%AAIVT%E6%A7%8B%E9%80%A0%3C%2FP%3E%3CP%3E%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%82%8BIVT%E6%A7%8B%E9%80%A0%EF%BC%9A%3CBR%20%2F%3E%20IVT%20HDR%20%3D%200x4X2000D1%3CBR%20%2F%3E%20IVT%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%20%3D%200xXXXXXXXX%3CBR%20%2F%3E%20IVT%20RSV1%20%3D%200x0%3CBR%20%2F%3E%20IVT%20DCD%20%3D%200x0%3CBR%20%2F%3E%20IVT%20BOOT_DATA%20%3D%200xXXXXXXXX%3CBR%20%2F%3E%20IVT%20SELF%20%3D%200xXXXXXXXX%3CBR%20%2F%3E%20IVT%20CSF%20%3D%200xXXXXXXXX%3CBR%20%2F%3E%20IVT%20RSV2%20%3D%200x0%3CBR%20%2F%3E%20zImage%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3EzImage%E3%82%92%E8%AA%8D%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%95%E3%82%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%BD%95%E3%81%8B%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HABv4%20on%20imx6ull%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AB%E3%81%AFCAAM%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%88%A5%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%82%92%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3E%5BHeader%5D%3CBR%20%2F%3EVersion%20%3D%204.2%3CBR%20%2F%3EHash%20Algorithm%20%3D%20sha256%3CBR%20%2F%3EEngine%20Configuration%20%3D%200%3CBR%20%2F%3ECertificate%20Format%20%3D%20X509%3CBR%20%2F%3ESignature%20Format%20%3D%20CMS%3CBR%20%2F%3E%3CSTRONG%3EEngine%20%3D%20SW%3C%2FSTRONG%3E%3C%2FPRE%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2335792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20HABv4%20on%20imx6ull%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2335792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AEcsf_uboot.txt%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%E3%83%98%E3%83%83%E3%83%80%5D%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20%3D%204.2%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20%3D%20sha256%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E6%A7%8B%E6%88%90%20%3D%200%3C%2FP%3E%3CP%3E%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20%3D%20X509%3C%2FP%3E%3CP%3E%E7%BD%B2%E5%90%8D%E5%BD%A2%E5%BC%8F%20%3D%20CMS%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20%3D%20CAAM%3C%2FP%3E%3CP%3E%5BSRK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3C%2FP%3E%3CP%3E%23%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8BSRK%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E5%86%85%E3%81%AE%E3%82%AD%E3%83%BC%E4%BD%8D%E7%BD%AE%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%2Fcrts%2FSRK_1_2_3_4_table.bin%22%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FP%3E%3CP%3E%5BCSFK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3C%2FP%3E%3CP%3E%23%20CSF%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AD%E3%83%BC%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%2Fcrts%2FCSF1_1_sha256_2048_65537_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5BCSF%E3%81%AE%E8%AA%8D%E8%A8%BC%5D%3C%2FP%3E%3CP%3E%5B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%BC%5D%3C%2FP%3E%3CP%3E%23%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%82%AD%E3%83%BC%E3%82%92%E8%AA%8D%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%3CP%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FP%3E%3CP%3E%23%20HAB%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E5%86%85%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%E7%9B%AE%E6%A8%99%E6%8C%87%E6%95%B0%20%3D%202%3C%2FP%3E%3CP%3E%23%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%BC%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3D%20%22..%2Fcrts%2FIMG1_1_sha256_2048_65537_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%8D%E8%A8%BC%5D%3C%2FP%3E%3CP%3E%23%20%E7%94%BB%E5%83%8F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%3CP%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202%3C%2FP%3E%3CP%3E%23%20%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%80%81%E9%95%B7%E3%81%95%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%AA%8D%E8%A8%BC%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%3D%200x877ff400%200x00000000%200x00082c00%20%22u-boot-dtb.imx%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HABv4%20on%20imx6ull%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%E7%94%BB%E5%83%8F%E8%AA%8D%E8%A8%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%89%8B%E9%A0%86%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Bopi%3D89978449%26amp%3Burl%3Dhttps%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2Fimx-processors%2F60046%2F1%2Fi.MX_6_Linux_High_Assurance_Boot_(HAB)_User%252527s_Guide.pdf%26amp%3Bved%3D2ahUKEwib4rqUg6-TAxV0HkQIHYxGAo4QFnoECAwQAQ%26amp%3Busg%3DAOvVaw3KfpbSCOakrVf3iJCP6h0M%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%82%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FSecure-boot-imx6-Invalid-IVT-structure%2Ftd-p%2F1618944%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FSecure-boot-imx6-Invalid-IVT-structure%2Ftd-p%2F1618944%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.ezurio.com%2Fdocumentation%2Fhigh-assurance-boot-hab-for-dummies%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.ezurio.com%2Fdocumentation%2Fhigh-assurance-boot-hab-for-dummies%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
