HAB SRK revoke
HAB SRK revoke
2,715件の閲覧回数
yosri_c
Hello NXP Support,
I'm using an RT1176 board with HABv4 (CST 4.0.1). I currently have my image signed using SRK1, but I need to switch to using SRK2 instead. (we're trying to test the image with SRK2 before revoking SRK1)
In my current CSF file, I have:
text
[Install SRK]
File = "..\..\crts\SRK_1_2_3_4_table.bin"
Source index = 0
[Install CSFK]
File = "CSF1_1_sha256_secp256r1_v3_usr_crt.pem"
[Authenticate CSF]
[Install Key]
Verification index = 0
Target index = 2
File = "IMG1_1_sha256_secp256r1_v3_usr_crt.pem"
[Authenticate Data]
Verification index = 2
Engine = CAAM
Engine Configuration = 0
Blocks = 0x80000000 0x0 0x8000 "BOOT.bin"
Could you please explain:
  1. What is the simplest way to change from SRK1 to SRK2?
  2. What changes do I need to make in my CSF file?
  3. Do I only need to change the Source index in [Install SRK] from 0 to 1?
Thank you for your help.
タグ(1)
4 返答(返信)
2,657件の閲覧回数
Bio_TICFSL
Yes, the simplest way to change from using SRK1 to SRK2 is to modify the Source index parameter in the [Install SRK] section of your CSF file from 0 to 1.
In your current CSF file:
[Install SRK]
Source index = 0
You should change this to:
[Install SRK]
Source index = 1
The Source index parameter determines which key in the SRK table will be used. Index 0 corresponds to SRK1, index 1 to SRK2, and so on.
You will also need to reference the appropriate certificate files for CSF2 and IMG2 instead of CSF1 and IMG1 in your CSF file, replacing:
- "CSF1_1_sha256_secp256r1_v3_usr_crt.pem" with "CSF2_1_sha256_secp256r1_v3_usr_crt.pem"
- "IMG1_1_sha256_secp256r1_v3_usr_crt.pem" with "IMG2_1_sha256_secp256r1_v3_usr_crt.pem"
This approach allows you to test using SRK2 before permanently revoking SRK1.
2,496件の閲覧回数
yosri_c
@Bio Thank you for your previous clarifications.
I have a critical follow-up regarding the security logic and the SRK migration process during a firmware update.
Our Current Scenario: Normal Boot: The device boots using SRK1 (Index 0). The chain of trust is fully established: ROM -> Bootloader (SRK1) -> Application (SRK1).
Firmware Update: While the system is running under the trust of SRK1, we download a new full image (BS + App) into SDRAM, signed with SRK2 (Index 1).
Verification: The currently running Bootloader calls hab_rvt.authenticate_image() to verify the new image in SDRAM.
My questions are:
1. Regarding runtime SRK switching: Can you confirm that the HAB library allows the execution of a new [Install SRK] command with Source index = 1 (SRK2) within the same power cycle, even if SRK1 was used for the initial boot?
2. Regarding revocation in the same cycle: Would it be possible, during this update process, to revoke SRK1 (by burning the SRK_REVOKE eFuse), then install SRK2 and perform the verification of the new RAM image, all within the same power cycle? Thank you
タグ(1)
2,268件の閲覧回数
yosri_c
@Bio_TICFSL
can you assist  please , anything would be helpful
Thank you
2,691件の閲覧回数
yosri_c
i tried changing
[Install SRK]
File = "SRK_1_2_3_4_table.bin"
Source index = 1
[Install CSFK]
File = "CSF2_1_sha256_secp256r1_v3_usr_crt.pem"
[Install Key]
Target index = 2
File = "IMG2_1_sha256_secp256r1_v3_usr_crt.pem"
to eventually use SRK 2 but i get these events
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2260148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHAB%20SRK%E5%8F%96%E3%82%8A%E6%B6%88%E3%81%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%A7%81%E3%81%AFHABv4%20(CST%204.0.1)%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT1176%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%20SRK1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SRK2%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82(SRK1%20%E3%82%92%E5%8F%96%E3%82%8A%E6%B6%88%E3%81%99%E5%89%8D%E3%81%AB%E3%80%81SRK2%20%E3%81%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%20CSF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%96%87%E7%AB%A0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%5BSRK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%5C..%5Ccrts%5CSRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FP%3E%3CP%3E%5BCSFK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22CSF1_1_sha256_secp256r1_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5BCSF%E3%81%AE%E8%AA%8D%E8%A8%BC%5D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%5B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%BC%5D%3CBR%20%2F%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22IMG1_1_sha256_secp256r1_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%8D%E8%A8%BC%5D%3CBR%20%2F%3E%E6%A4%9C%E8%A8%BC%E6%8C%87%E6%95%B0%20%3D%202%3CBR%20%2F%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20%3D%20CAAM%3CBR%20%2F%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E6%A7%8B%E6%88%90%20%3D%200%3CBR%20%2F%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%3D%200x80000000%200x0%200x8000%20%22BOOT.bin%22%3C%2FP%3E%3CBR%20%2F%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ESRK1%20%E3%81%8B%E3%82%89%20SRK2%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E6%9C%80%E3%82%82%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ECSF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%5BInstall%20SRK%5D%3CSPAN%3E%E3%81%AE%3C%2FSPAN%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%200%3CSPAN%3E%E3%81%8B%E3%82%89%3C%2FSPAN%3E1%3CSPAN%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3C%2FSPAN%3E%3CSPAN%3E%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5BSRK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22SRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201%3C%2FP%3E%3CP%3E%5BCSFK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22CSF2_1_sha256_secp256r1_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%BC%5D%3CBR%20%2F%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22IMG2_1_sha256_secp256r1_v3_usr_crt.pem%22%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%81%AFSRK%202%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369551i0898F08D74731ED9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yosri_c_1-1765463880990.png%22%20alt%3D%22yosri_c_1-1765463880990.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2261295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%AF%E3%81%84%E3%80%81SRK1%20%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8B%E3%82%89%20SRK2%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E6%9C%80%E3%82%82%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81CSF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%20%5BInstall%20SRK%5D%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%82%E3%82%8B%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%200%20%E3%81%8B%E3%82%89%201%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%20CSF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3A%3CBR%20%2F%3E%20%E3%80%8C%E3%80%8D%3CBR%20%2F%3E%20%5BSRK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%5C..%5Ccrts%5CSRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3CBR%20%2F%3E%20%E3%80%8C%E3%80%8D%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%E3%80%8C%E3%80%8D%3CBR%20%2F%3E%20%5BSRK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%5C..%5Ccrts%5CSRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201%3CBR%20%2F%3E%20%E3%80%8C%E3%80%8D%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E3%80%81SRK%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E5%86%85%E3%81%AE%E3%81%A9%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%200%20%E3%81%AF%20SRK1%20%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%201%20%E3%81%AF%20SRK2%20%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81CSF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AE%20CSF1%20%E3%81%A8%20IMG1%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81CSF2%20%E3%81%A8%20IMG2%20%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20-%20%E3%80%8CCSF1_1_sha256_secp256r1_v3_usr_crt.pem%E3%80%8D%E3%81%A8%E3%80%8CCSF2_1_sha256_secp256r1_v3_usr_crt.pem%E3%80%8D%3CBR%20%2F%3E%20-%20%E3%80%8CIMG1_1_sha256_secp256r1_v3_usr_crt.pem%E3%80%8D%E3%81%A8%E3%80%8CIMG2_1_sha256_secp256r1_v3_usr_crt.pem%E3%80%8D%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81SRK1%20%E3%82%92%E6%B0%B8%E4%B9%85%E3%81%AB%E5%8F%96%E3%82%8A%E6%B6%88%E3%81%99%E5%89%8D%E3%81%AB%20SRK2%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%40Bio%20%E5%89%8D%E5%9B%9E%E3%81%AE%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E4%B8%AD%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%A8%20SRK%20%E7%A7%BB%E8%A1%8C%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%3A%20%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%20SRK1%20(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%200)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BF%A1%E9%A0%BC%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20ROM%20-%26gt%3B%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%20(SRK1)%20-%26gt%3B%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20(SRK1)%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9B%B4%E6%96%B0%3A%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%20SRK1%20%E3%81%AE%E4%BF%A1%E9%A0%BC%E3%81%AE%E4%B8%8B%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%81%AB%E3%80%81SRK2%20(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%201)%20%E3%81%A7%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(BS%20%2B%20App)%20%E3%82%92%20SDRAM%20%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A4%9C%E8%A8%BC%3A%20%E7%8F%BE%E5%9C%A8%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AF%E3%80%81hab_rvt.authenticate_image()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E3%80%81SDRAM%20%E5%86%85%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E1.%20%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%20SRK%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3A%20%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%20SRK1%20%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81HAB%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A7%E3%80%81%E5%90%8C%E3%81%98%E9%9B%BB%E6%BA%90%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E5%86%85%E3%81%A7%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201%20(SRK2)%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20%5BInstall%20SRK%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%8C%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2.%20%E5%90%8C%E3%81%98%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A7%E3%81%AE%E5%A4%B1%E5%8A%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3A%20%E3%81%93%E3%81%AE%E6%9B%B4%E6%96%B0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AB%E3%80%81SRK1%20%E3%82%92%E5%A4%B1%E5%8A%B9%E3%81%95%E3%81%9B%20(SRK_REVOKE%20eFuse%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6)%E3%80%81%E6%AC%A1%E3%81%AB%20SRK2%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20RAM%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E6%93%8D%E4%BD%9C%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E5%90%8C%E3%81%98%E9%9B%BB%E6%BA%90%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E5%86%85%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E4%BD%95%E3%81%A7%E3%82%82%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
