HAB SRK revoke
HAB SRK revoke
2,645 次查看
yosri_c
Hello NXP Support,
I'm using an RT1176 board with HABv4 (CST 4.0.1). I currently have my image signed using SRK1, but I need to switch to using SRK2 instead. (we're trying to test the image with SRK2 before revoking SRK1)
In my current CSF file, I have:
text
[Install SRK]
File = "..\..\crts\SRK_1_2_3_4_table.bin"
Source index = 0
[Install CSFK]
File = "CSF1_1_sha256_secp256r1_v3_usr_crt.pem"
[Authenticate CSF]
[Install Key]
Verification index = 0
Target index = 2
File = "IMG1_1_sha256_secp256r1_v3_usr_crt.pem"
[Authenticate Data]
Verification index = 2
Engine = CAAM
Engine Configuration = 0
Blocks = 0x80000000 0x0 0x8000 "BOOT.bin"
Could you please explain:
  1. What is the simplest way to change from SRK1 to SRK2?
  2. What changes do I need to make in my CSF file?
  3. Do I only need to change the Source index in [Install SRK] from 0 to 1?
Thank you for your help.
标记 (1)
4 回复数
2,587 次查看
Bio_TICFSL
Yes, the simplest way to change from using SRK1 to SRK2 is to modify the Source index parameter in the [Install SRK] section of your CSF file from 0 to 1.
In your current CSF file:
[Install SRK]
Source index = 0
You should change this to:
[Install SRK]
Source index = 1
The Source index parameter determines which key in the SRK table will be used. Index 0 corresponds to SRK1, index 1 to SRK2, and so on.
You will also need to reference the appropriate certificate files for CSF2 and IMG2 instead of CSF1 and IMG1 in your CSF file, replacing:
- "CSF1_1_sha256_secp256r1_v3_usr_crt.pem" with "CSF2_1_sha256_secp256r1_v3_usr_crt.pem"
- "IMG1_1_sha256_secp256r1_v3_usr_crt.pem" with "IMG2_1_sha256_secp256r1_v3_usr_crt.pem"
This approach allows you to test using SRK2 before permanently revoking SRK1.
2,426 次查看
yosri_c
@Bio Thank you for your previous clarifications.
I have a critical follow-up regarding the security logic and the SRK migration process during a firmware update.
Our Current Scenario: Normal Boot: The device boots using SRK1 (Index 0). The chain of trust is fully established: ROM -> Bootloader (SRK1) -> Application (SRK1).
Firmware Update: While the system is running under the trust of SRK1, we download a new full image (BS + App) into SDRAM, signed with SRK2 (Index 1).
Verification: The currently running Bootloader calls hab_rvt.authenticate_image() to verify the new image in SDRAM.
My questions are:
1. Regarding runtime SRK switching: Can you confirm that the HAB library allows the execution of a new [Install SRK] command with Source index = 1 (SRK2) within the same power cycle, even if SRK1 was used for the initial boot?
2. Regarding revocation in the same cycle: Would it be possible, during this update process, to revoke SRK1 (by burning the SRK_REVOKE eFuse), then install SRK2 and perform the verification of the new RAM image, all within the same power cycle? Thank you
标记 (1)
2,198 次查看
yosri_c
@Bio_TICFSL
can you assist  please , anything would be helpful
Thank you
2,621 次查看
yosri_c
i tried changing
[Install SRK]
File = "SRK_1_2_3_4_table.bin"
Source index = 1
[Install CSFK]
File = "CSF2_1_sha256_secp256r1_v3_usr_crt.pem"
[Install Key]
Target index = 2
File = "IMG2_1_sha256_secp256r1_v3_usr_crt.pem"
to eventually use SRK 2 but i get these events
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2260148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHAB%20SRK%20%E6%92%A4%E9%94%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20Habv4%20(CST%204.0.1)%20%E7%9A%84%20RT1176%20%E6%9D%BF%E3%80%82%E6%88%91%E7%9B%AE%E5%89%8D%E4%BD%BF%E7%94%A8%20SRK1%20%E5%AF%B9%E5%9B%BE%E5%83%8F%E8%BF%9B%E8%A1%8C%E7%AD%BE%E5%90%8D%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E6%94%B9%E7%94%A8%20SRK2%E3%80%82(%E6%88%91%E4%BB%AC%E8%AF%95%E5%9B%BE%E5%9C%A8%E6%92%A4%E9%94%80%20SRK1%20%E4%B9%8B%E5%89%8D%E7%94%A8%20SRK2%20%E6%B5%8B%E8%AF%95%E5%9B%BE%E5%83%8F%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E5%9C%A8%E6%88%91%E7%9B%AE%E5%89%8D%E7%9A%84%20CSF%20%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E6%88%91%E6%9C%89%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%96%87%E6%9C%AC%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%5BInstall%20SRK%5D%3CBR%20%2F%3EFile%20%3D%22..%5C..%5Ccrts%5CSRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%20Source%20index%20%3D%200%3C%2FP%3E%3CP%3E%5BInstall%20CSFK%5D%3CBR%20%2F%3EFile%20%3D%22CSF1_1_sha256_secp256r1_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5B%E9%AA%8C%E8%AF%81%20CSF%EF%BC%BD%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%5BInstall%20Key%5D%3CBR%20%2F%3EVerification%20index%20%3D%200%3CBR%20%2F%3ETarget%20index%20%3D%202%3CBR%20%2F%3EFile%20%3D%22IMG1_1_sha256_secp256r1_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5B%E9%AA%8C%E8%AF%81%E6%95%B0%E6%8D%AE%5D%20%3CBR%20%2F%3E%20%E9%AA%8C%E8%AF%81%E6%8C%87%E6%95%B0%20%3D%202%20%3CBR%20%2F%3E%20%E5%BC%95%E6%93%8E%20%3D%20CAAM%20%3CBR%20%2F%3E%20%E5%BC%95%E6%93%8E%E9%85%8D%E7%BD%AE%20%3D%200%20%3CBR%20%2F%3E%20%E5%8C%BA%E5%9D%97%20%3D%200x80000000%200x0%200x8000%20%22%E5%90%AF%E5%8A%A8.bin%22%3C%2FP%3E%3CBR%20%2F%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%AF%B7%E6%82%A8%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E4%BB%8E%20SRK1%20%E8%BD%AC%E5%88%B0%20SRK2%20%E7%9A%84%E6%9C%80%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E7%9A%84%20CSF%20%E6%96%87%E4%BB%B6%E9%9C%80%E8%A6%81%E5%81%9A%E5%93%AA%E4%BA%9B%E6%9B%B4%E6%94%B9%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AA%E9%9C%80%E8%A6%81%E5%B0%86%20%3C%2FSPAN%3E%5BInstall%20SRK%5D%3CSPAN%3E%20%E4%B8%AD%E7%9A%84%20%3C%2FSPAN%3E%E6%BA%90%E4%BB%A3%E7%A0%81%E7%B4%A2%E5%BC%95%3CSPAN%3E%20%E4%BB%8E%20%3C%2FSPAN%3E0%3CSPAN%3E%20%E6%94%B9%E4%B8%BA%20%3C%2FSPAN%3E1%3CSPAN%3E%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E6%9B%B4%E6%94%B9%20%3C%2FP%3E%3CP%3E%5BInstall%20SRK%5D%3CBR%20%2F%3EFile%20%3D%22SRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%E6%9D%A5%E6%BA%90%E6%8C%87%E6%95%B0%20%3D%201%3C%2FP%3E%3CP%3E%5BInstall%20CSFK%5D%3CBR%20%2F%3EFile%20%3D%22CSF2_1_sha256_secp256r1_v3_usr_crt.pem%22%3C%2FP%3E%3CP%3E%5BInstall%20Key%5D%3CBR%20%2F%3EVerification%20index%20%3D%200%3CBR%20%2F%3ETarget%20index%20%3D%202%3CBR%20%2F%3EFile%20%3D%22IMG2_1_sha256_secp256r1_v3_usr_crt.pem%22%20%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E6%9C%80%E7%BB%88%E4%BD%BF%E7%94%A8%20SRK%202%EF%BC%8C%E4%BD%86%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%BA%9B%E4%BA%8B%E4%BB%B6%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yosri_c_1-1765463880990.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369551i0898F08D74731ED9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yosri_c_1-1765463880990.png%22%20alt%3D%22yosri_c_1-1765463880990.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2261295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BB%8E%E4%BD%BF%E7%94%A8%20SRK1%20%E5%88%B0%E4%BD%BF%E7%94%A8%20SRK2%20%E7%9A%84%E6%9C%80%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%E6%98%AF%E4%BF%AE%E6%94%B9%20CSF%20%E6%96%87%E4%BB%B6%E4%B8%AD%20%5BInstall%20SRK%5D%20%E9%83%A8%E5%88%86%E7%9A%84%E6%BA%90%E7%B4%A2%E5%BC%95%E5%8F%82%E6%95%B0%EF%BC%8C%E4%BB%8E%200%20%E6%94%B9%E4%B8%BA%201%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E6%82%A8%E5%BD%93%E5%89%8D%E7%9A%84%20CSF%20%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%5BInstall%20SRK%5D%3CBR%20%2F%3EFile%20%3D%22..%5C..%5Ccrts%5CSRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%20%E6%BA%90%E7%B4%A2%E5%BC%95%20%3D%200%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%82%A8%E5%BA%94%E5%B0%86%E5%85%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%EF%BC%9A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%5BInstall%20SRK%5D%3CBR%20%2F%3EFile%20%3D%22..%5C..%5Ccrts%5CSRK_1_2_3_4_table.bin%22%3CBR%20%2F%3E%20Source%20index%20%3D%201%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%BA%90%E7%B4%A2%E5%BC%95%E5%8F%82%E6%95%B0%E5%86%B3%E5%AE%9A%E5%B0%86%E4%BD%BF%E7%94%A8%20SRK%20%E8%A1%A8%E4%B8%AD%E7%9A%84%E5%93%AA%E4%B8%AA%E9%94%AE%E3%80%82%E7%B4%A2%E5%BC%95%200%20%E5%AF%B9%E5%BA%94%20SRK1%EF%BC%8C%E7%B4%A2%E5%BC%95%201%20%E5%AF%B9%E5%BA%94%20SRK2%EF%BC%8C%E4%BB%A5%E6%AD%A4%E7%B1%BB%E6%8E%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E8%BF%98%E9%9C%80%E8%A6%81%E5%9C%A8%20CSF%20%E6%96%87%E4%BB%B6%E4%B8%AD%E5%BC%95%E7%94%A8%20CSF2%20%E5%92%8C%20IMG2%20%E7%9A%84%E7%9B%B8%E5%BA%94%E8%AF%81%E4%B9%A6%E6%96%87%E4%BB%B6%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20CSF1%20%E5%92%8C%20IMG1%EF%BC%8C%E6%9B%BF%E6%8D%A2%EF%BC%9A%3CBR%20%2F%3E-%22%20csf1_1_sha256_secp256r1_v3_usr_crt.pem%20%22%20%E6%9B%BF%E6%8D%A2%E4%B8%BA%20%22%20CSF2_1_SHA256_secp256r1_v3_usr_crt.pem%20%22%20%22%20g1_1_sha256_secp256r1_v3_usr_crt.pem%20%22%20%E5%B8%A6%E6%9C%89%20%22%20img2_1_SHA256_secp256_secp256r1_v3_%20%3CBR%20%2F%3Eusr_crt.pem%20%22%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E5%85%81%E8%AE%B8%E6%82%A8%E5%9C%A8%E6%B0%B8%E4%B9%85%E6%92%A4%E9%94%80%20SRK1%20%E4%B9%8B%E5%89%8D%E4%BD%BF%E7%94%A8%20SRK2%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%40Bio%20%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B9%8B%E5%89%8D%E7%9A%84%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%88%91%E5%B0%86%E5%AF%B9%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E9%80%BB%E8%BE%91%E5%92%8C%20SRK%20%E8%BF%81%E7%A7%BB%E8%BF%87%E7%A8%8B%E8%BF%9B%E8%A1%8C%E9%87%8D%E8%A6%81%E7%9A%84%E5%90%8E%E7%BB%AD%E8%B7%9F%E8%BF%9B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%BD%93%E5%89%8D%E7%9A%84%E5%9C%BA%E6%99%AF%EF%BC%9A%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%BD%BF%E7%94%A8%20SRK1%EF%BC%88%E7%B4%A2%E5%BC%95%200%EF%BC%89%E5%90%AF%E5%8A%A8%E3%80%82%E4%BF%A1%E4%BB%BB%E9%93%BE%E5%B7%B2%E5%AE%8C%E5%85%A8%E5%BB%BA%E7%AB%8B%EF%BC%9AROM%20-%26gt%3B%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20(SRK1)%20-%26gt%3B%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20(SRK1)%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%EF%BC%9A%E5%BD%93%E7%B3%BB%E7%BB%9F%E5%9C%A8%20SRK1%20%E7%9A%84%E4%BF%A1%E4%BB%BB%E4%B8%8B%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%BD%BF%E7%94%A8%20SRK2%EF%BC%88%E7%B4%A2%E5%BC%95%201%EF%BC%89%E7%AD%BE%E5%90%8D%E7%9A%84%E6%96%B0%E5%AE%8C%E6%95%B4%E6%98%A0%E5%83%8F%EF%BC%88BS%20%2B%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E4%B8%8B%E8%BD%BD%E5%88%B0%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E9%AA%8C%E8%AF%81%EF%BC%9A%E5%BD%93%E5%89%8D%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%20Bootloader%20%E8%B0%83%E7%94%A8%20hab_rvt.authenticate_image()%20%E6%9D%A5%E9%AA%8C%E8%AF%81%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E4%B8%AD%E7%9A%84%E6%96%B0%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%3C%2FP%3E%3CP%3E1%E3%80%82%E5%85%B3%E4%BA%8E%E8%BF%90%E8%A1%8C%E6%97%B6%20SRK%20%E5%88%87%E6%8D%A2%EF%BC%9A%E4%BD%A0%E8%83%BD%E5%90%A6%E7%A1%AE%E8%AE%A4%20HAB%20%E5%BA%93%E5%85%81%E8%AE%B8%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E7%94%B5%E6%BA%90%E5%91%A8%E6%9C%9F%E5%86%85%E6%89%A7%E8%A1%8C%E6%BA%90%E7%B4%A2%E5%BC%95%20%3D%201%20(SRK2)%20%E7%9A%84%E6%96%B0%20%5B%E5%AE%89%E8%A3%85%20SRK%5D%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%88%9D%E5%A7%8B%E5%90%AF%E5%8A%A8%E6%97%B6%E4%BD%BF%E7%94%A8%E4%BA%86%20SRK1%EF%BC%9F%3C%2FP%3E%3CP%3E2.%E5%85%B3%E4%BA%8E%E5%9C%A8%E5%90%8C%E4%B8%80%E5%91%A8%E6%9C%9F%E5%86%85%E6%92%A4%E9%94%80%EF%BC%9A%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%E6%9B%B4%E6%96%B0%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%92%A4%E9%94%80%20SRK1%EF%BC%88%E9%80%9A%E8%BF%87%E7%83%A7%E5%BD%95%20SRK_REVOKE%20eFuse%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AE%89%E8%A3%85%20SRK2%20%E5%B9%B6%E5%AF%B9%E6%96%B0%E7%9A%84%20RAM%20%E6%98%A0%E5%83%8F%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%EF%BC%8C%E6%89%80%E6%9C%89%E8%BF%99%E4%B8%80%E5%88%87%E9%83%BD%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E7%94%B5%E6%BA%90%E5%91%A8%E6%9C%9F%E5%86%85%E5%AE%8C%E6%88%90%EF%BC%9F%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HAB%20SRK%20revoke%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%E9%83%BD%E5%B0%86%E6%98%AF%E6%9C%89%E7%9B%8A%E7%9A%84%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
