Guide AN13970 Incorrect
gfrung
This guide is incorrect and does not work for the i.MX 8ULP:
AN13970: Running Zephyr RTOS on Cadence Tensilica HiFi 4 DSP | NXP Semiconductors
Specifically, this line:
For i.MX 8ULP (imx8ulp_evk/mimx8ud7/adsp board), the above command can be used.
In fact, the command does not work for the i.MX 8ULP.  This command results in an error:
> west build -p always -b imx8ulp_evk/mimx8ud7/adsp samples/subsys/ipc/openamp_rsc_table
zephyrproject/zephyr/samples/subsys/ipc/openamp_rsc_table/src/main_remote.c:31:2: error: #error "Sample requires definition of shared memory for rpmsg"
31 | #error "Sample requires definition of shared memory for rpmsg"
I'm not asking how to fix this error; I'm letting you know that the guide is incorrect.  Please correct the guide with any additional steps required for a successful build on the i.MX 8ULP, so it can aid future readers.
Note that the steps in the guide work fine for the other three processors: i.MX 8M Plus, i.MX 8QuadMax and i.MX 8QuadXPlus.  So, it is just the i.MX 8ULP portion that needs correcting.
Zhiming_Liu
According to the author, the following pull requests has not been fully merged at the moment:
https://github.com/zephyrproject-rtos/zephyr/pull/83049
https://github.com/zephyrproject-rtos/zephyr/pull/84170
You may try these code themselves, or wait until they get merged.
Note that for the sample to work on i.MX 8ULP, there's also a pending patch for Linux Kernel:
https://patchwork.kernel.org/project/linux-remoteproc/patch/20250305123923.514386-1-iuliana.prodan@o...
Zhiming
Zhiming_Liu
Zhiming
Zhiming_Liu
Have reported this issue and i will update here once get the solution.
Zhiming
