GStreamer streaming - has client to start first?
已解决
跳至解决方案
3,591 次查看
martink_
Hi community,
I am able to stream h264 or MPEG4 video. Client (player) has to be started first and then start streaming (start server).
What I need is to be able to connect to the already playing stream (start client after server).
Both server and client run on same i.MX6 device.
Server example: gst-launch-0.10 -vvv filesrc location=bruce.mp4 typefind=true ! qtdemux name=demux demux.video_00 ! queue ! h264parse split-packetized=true ! mpegtsmux ! rtpmp2tpay ! gdppay ! udpsink host=239.255.1.1 port=5004
Client example: gst-launch-0.10 -vvv udpsrc port=5004 multicast-group=239.255.1.1 caps="application/x-gdp" ! gdpdepay ! gstrtpjitterbuffer ! rtpmp2tdepay ! mpegtsdemux name=demux ! queue max-size-buffers=0 max-size-time=0 ! vpudec low-latency=true framedrop=true ! mfw_isink sync=false
标记 (2)
1 解答
2,869 次查看
martink_
Sorry, my mistake. Done.
在原帖中查看解决方案
2 回复数
2,869 次查看
Wlodek_D_
Senior Contributor II
Dear Martin K.
Thank you for your post, however please consider moving it to the right community place (e.g. i.MX Community )  for better visibility.
For details please see general advice https://community.freescale.com/docs/DOC-99909
Thank you for using Freescale Community.
Wlodek_D.
2,870 次查看
martink_
