GStreamer C application
1,547件の閲覧回数
giritharanr
Hi i want to write a GStreamer Application using C Language for this GStreamer command  (gst-launch –e mfw_v4lsrc capture-mode=1 fps-n=30 ! vpuenc codec=0 ! queue ! mux. alsasrc ! 'audio/x-raw-int,rate=48000,channels=1' ! mfw_mp3encoder ! queue ! mux. avimux name=mux ! filesink location=audio_video.avi sync=false).
I attach sample C application source code.While running this code i got segmentation fault error and some error.
And the thing is i dont know how to add  the following things :
! mux. alsasrc
! mux. avimux name=mux.
So please help to complete the C application as per the gstreamer command i give.
Thanks .
With Regards,
R.Giritharan
Original Attachment has been moved to: Giri_Gstreamer.c.zip
ラベル(3)
タグ(1)
1,307件の閲覧回数
joanxie
what board do you use? did you try to use freescale gstreamer to encode? any issues?
