GSM module detection issue on SM2S-IMX93
sarathcdac07
I am working on imx93 board and i have a GSM module of sierra em9291, which is connected to the obu board using M.2 slot. The device is expected to be detected as a USB device, but the module is not getting detected. It is confirmed that the module is working. I am attaching the dmesg received while booting the obu board.
[ 0.931828] VFIO - User Level meta-driver version: 0.3
[ 0.938331] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.944887] ehci-pci: EHCI PCI platform driver
[ 0.949365] ehci-platform: EHCI generic platform driver
[ 0.954737] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.960930] ohci-pci: OHCI PCI platform driver
[ 0.965405] ohci-platform: OHCI generic platform driver
[ 0.971142] usbcore: registered new interface driver uas
[ 0.976500] usbcore: registered new interface driver usb-storage
[ 0.982570] usbcore: registered new interface driver usbserial_generic
[ 0.989104] usbserial: USB Serial support registered for generic
[ 0.995126] usbcore: registered new interface driver ftdi_sio
[ 1.000867] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.008187] usbcore: registered new interface driver qcaux
[ 1.013668] usbserial: USB Serial support registered for qcaux
[ 1.019508] usbcore: registered new interface driver qcserial
[ 1.025262] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.032230] usbcore: registered new interface driver sierra
[ 1.037803] usbserial: USB Serial support registered for Sierra USB modem
[ 1.044605] usbcore: registered new interface driver usb_serial_simple
[ 1.051134] usbserial: USB Serial support registered for carelink
[ 1.057225] usbserial: USB Serial support registered for zio
[ 1.062885] usbserial: USB Serial support registered for funsoft
[ 1.068896] usbserial: USB Serial support registered for flashloader
[ 1.075243] usbserial: USB Serial support registered for google
[ 1.081165] usbserial: USB Serial support registered for libtransistor
[ 1.087688] usbserial: USB Serial support registered for vivopay
[ 1.093694] usbserial: USB Serial support registered for moto_modem
[ 1.099962] usbserial: USB Serial support registered for motorola_tetra
[ 1.106578] usbserial: USB Serial support registered for nokia
[ 1.112406] usbserial: USB Serial support registered for novatel_gps
[ 1.118758] usbserial: USB Serial support registered for hp4x
[ 1.124505] usbserial: USB Serial support registered for suunto
[ 1.130430] usbserial: USB Serial support registered for siemens_mpi
[ 1.136787] usbcore: registered new interface driver usb_ehset_test
[ 1.144781] bbnsm_pwrkey 44440000.bbnsm:pwrkey: KEY_POWER without setting in dts
[ 1.153199] input: 44440000.bbnsm:pwrkey as /devices/platform/soc@0/44000000.bus/44440000.bbnsm/44440000.bbnsm:pwrkey/input/input0
[ 1.168562] bbnsm_rtc 44440000.bbnsm:rtc: registered as rtc1
[ 1.174625] i2c_dev: i2c /dev entries driver
[ 1.180869] Bluetooth: HCI UART driver ver 2.3
[ 1.185332] Bluetooth: HCI UART protocol H4 registered
[ 1.190459] Bluetooth: HCI UART protocol BCSP registered
[ 1.195781] Bluetooth: HCI UART protocol LL registered
[ 1.200911] Bluetooth: HCI UART protocol ATH3K registered
[ 1.206312] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.212646] Bluetooth: HCI UART protocol Broadcom registered
[ 1.218306] Bluetooth: HCI UART protocol QCA registered
[ 1.224585] sdhci: Secure Digital Host Controller Interface driver
[ 1.230771] sdhci: Copyright(c) Pierre Ossman
[ 1.235471] Synopsys Designware Multimedia Card Interface Driver
[ 1.241788] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.248334] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.255190] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.262002] usbcore: registered new interface driver usbhid
[ 1.267582] usbhid: USB HID core driver
[ 1.274075] cs_system_cfg: CoreSight Configuration manager initialised
[ 1.279383] mmc0: SDHCI controller on 42850000.mmc [42850000.mmc] using ADMA
[ 1.281330] optee: probing for conduit method.
[ 1.292295] optee: revision 3.21 (4e322819)
[ 1.292765] optee: dynamic shared memory is enabled
[ 1.302169] optee: initialized driver
[ 1.309028] NET: Registered PF_LLC protocol family
[ 1.314219] NET: Registered PF_INET6 protocol family
[ 1.319851] Segment Routing with IPv6
[ 1.323558] In-situ OAM (IOAM) with IPv6
[ 1.327546] NET: Registered PF_PACKET protocol family
[ 1.332736] Bluetooth: RFCOMM TTY layer initialized
[ 1.337666] Bluetooth: RFCOMM socket layer initialized
[ 1.342834] Bluetooth: RFCOMM ver 1.11
[ 1.346599] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.351905] Bluetooth: BNEP filters: protocol multicast
[ 1.357134] Bluetooth: BNEP socket layer initialized
[ 1.362102] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.368173] Bluetooth: HIDP socket layer initialized
[ 1.373462] 8021q: 802.1Q VLAN Support v1.8
[ 1.377770] 9pnet: Installing 9P2000 support
[ 1.382072] tsn generic netlink module v1 init...
[ 1.386857] Key type dns_resolver registered
[ 1.391436] Loading compiled-in X.509 certificates
[ 1.401620] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.406271] usb_phy_generic soc@0:usbphynop1: supply vcc not found, using dummy regulator
[ 1.412543] mmcblk0: mmc0:0001 IB2916 14.6 GiB
[ 1.416324] usb_phy_generic soc@0:usbphynop1: dummy supplies not allowed for exclusive requests
[ 1.429790] usb_phy_generic soc@0:usbphynop2: supply vcc not found, using dummy regulator
[ 1.429826] mmcblk0boot0: mmc0:0001 IB2916 4.00 MiB
[ 1.438122] usb_phy_generic soc@0:usbphynop2: dummy supplies not allowed for exclusive requests
[ 1.444228] mmcblk0boot1: mmc0:0001 IB2916 4.00 MiB
[ 1.457681] mmcblk0rpmb: mmc0:0001 IB2916 4.00 MiB, chardev (510:0)
[ 1.462392] fsl_lpspi 42550000.spi: dma setup error -19, use pio
[ 1.471555] fsl_lpspi 42700000.spi: dma setup error -19, use pio
[ 1.481628] sdhci-esdhc-imx 42860000.mmc: Got CD GPIO
[ 1.483514] rtc-rs5c372 0-0032: r2223x found, 24hr
[ 1.491776] rtc-rs5c372 0-0032: eco mode enabled
[ 1.497022] rtc-rs5c372 0-0032: rtc oscillator interruption detected. Please reset the rtc clock.
[ 1.506032] rtc-rs5c372 0-0032: registered as rtc0
[ 1.511293] rtc-rs5c372 0-0032: rtc oscillator interruption detected. Please reset the rtc clock.
[ 1.518103] mmc1: SDHCI controller on 42860000.mmc [42860000.mmc] using ADMA
[ 1.520159] rtc-rs5c372 0-0032: hctosys: unable to read the hardware clock
[ 1.534862] i2c i2c-0: LPI2C adapter registered
[ 1.540762] VCC_SOC_0V8: Bringing 900000uV into 800000-800000uV
[ 1.550695] rn5t618 1-0030: running in single/master mode
[ 1.556229] i2c i2c-1: LPI2C adapter registered
[ 1.561451] i2c i2c-2: LPI2C adapter registered
[ 1.567013] pca953x 4-0022: supply vcc not found, using dummy regulator
[ 1.573737] pca953x 4-0022: using AI
[ 1.578406] gpio-488 (boot_sel0): hogged as input
[ 1.583227] gpio-489 (boot_sel1): hogged as input
[ 1.588029] gpio-490 (boot_sel2): hogged as input
[ 1.593032] gpio-498 (wifi_en): hogged as output/low
[ 1.598179] gpio-499 (gbe0_rst): hogged as output/high
[ 1.603518] gpio-500 (gbe1_rst): hogged as output/high
[ 1.608840] gpio-501 (usb_rst): hogged as output/low
[ 1.614112] i2c i2c-4: LPI2C adapter registered
[ 1.618686] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.624451] pps pps0: new PPS source ptp0
[ 1.634301] fec 42890000.ethernet eth0: registered PHC device 0
[ 1.641039] imx-dwmac 428a0000.ethernet: IRQ eth_lpi not found
[ 1.647260] imx-dwmac 428a0000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[ 1.654155] imx-dwmac 428a0000.ethernet: DWMAC4/5
[ 1.659958] imx-dwmac 428a0000.ethernet: DMA HW capability register supported
[ 1.667100] imx-dwmac 428a0000.ethernet: RX Checksum Offload Engine supported
[ 1.674235] imx-dwmac 428a0000.ethernet: TX Checksum insertion supported
[ 1.680926] imx-dwmac 428a0000.ethernet: Wake-Up On Lan supported
[ 1.687072] imx-dwmac 428a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.694737] imx-dwmac 428a0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 1.701520] imx-dwmac 428a0000.ethernet: Enabled RFS Flow TC (entries=8)
[ 1.708233] imx-dwmac 428a0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[ 1.715805] imx-dwmac 428a0000.ethernet: Using 32 bits DMA width
[ 1.721914] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.727699] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.729047] mmcblk1: mmc1:aaaa SK32G 29.7 GiB
[ 1.733484] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.745048] mmcblk1: p1 p2
[ 1.760163] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.765999] hub 1-0:1.0: USB hub found
[ 1.769782] hub 1-0:1.0: 1 port detected
[ 1.777856] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.782766] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 1.804160] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.810031] hub 2-0:1.0: USB hub found
[ 1.813807] hub 2-0:1.0: 1 port detected
[ 1.819619] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.828751] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.835382] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.836751] ALSA device list:
[ 1.844007] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 1.847023] No soundcards found.
[ 1.872310] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.882126] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 1.888794] devtmpfs: mounted
[ 1.893640] Freeing unused kernel memory: 2816K
[ 1.898295] Run /sbin/init as init process
[ 2.028179] usb 1-1: new full-speed USB device number 2 using ci_hdrc
[ 2.040991] systemd[1]: System time before build time, advancing clock.
[ 2.062635] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 2.093842] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 2.096607] systemd[1]: Detected architecture arm64.
Welcome to Poky (Yocto Project Reference Distro) 4.0.4 (kirkstone)!
[ 2.172996] systemd[1]: Hostname set to <sm2s-imx93>.
[ 2.199166] usb 1-1: not running at top speed; connect to a high speed hub
[ 2.244999] systemd-sysv-generator[162]: SysV service '/etc/init.d/cmdline-keyboard.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 2.271158] hub 2-1:1.0: USB hub found
[ 2.275119] hub 2-1:1.0: 4 ports detected
Bio_TICFSL
I confirm that the module is working but there is no driver for you GSM, so Adapt your driver with the latest BSP.
regards
sarathcdac07
Hello ,
As you suggested , I added the support for sierra em929x in my qcserial.c and qmi_wwan.c. Now this is the dmesg which i get. I am also attaching the driver files which i got from sierra official website.
[ 0.412001] usbcore: registered new interface driver usbfs
[ 0.417403] usbcore: registered new interface driver hub
[ 0.422531] usbcore: registered new device driver usb
[ 0.947802] usbcore: registered new interface driver asix
[ 0.953237] usbcore: registered new interface driver ax88179_178a
[ 0.959343] usbcore: registered new interface driver cdc_ether
[ 0.965189] usbcore: registered new interface driver cdc_eem
[ 0.970862] usbcore: registered new interface driver net1080
[ 0.976554] usbcore: registered new interface driver cdc_subset
[ 0.982493] usbcore: registered new interface driver zaurus
[ 0.988093] usbcore: registered new interface driver sierra_net
[ 0.994025] usbcore: registered new interface driver cdc_ncm
[ 0.999694] usbcore: registered new interface driver qmi_wwan
[ 1.005443] usbcore: registered new interface driver cdc_mbim
[ 1.018389] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.034796] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.051077] usbcore: registered new interface driver cdc_acm
[ 1.056733] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.064752] usbcore: registered new interface driver cdc_wdm
[ 1.070600] usbcore: registered new interface driver uas
[ 1.075953] usbcore: registered new interface driver usb-storage
[ 1.082007] usbcore: registered new interface driver usbserial_generic
[ 1.088535] usbserial: USB Serial support registered for generic
[ 1.094555] usbcore: registered new interface driver ftdi_sio
[ 1.100301] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.107612] usbcore: registered new interface driver option
[ 1.113189] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.120185] usbcore: registered new interface driver qcaux
[ 1.125668] usbserial: USB Serial support registered for qcaux
[ 1.131506] usbcore: registered new interface driver qcserial
[ 1.137254] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.144214] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.151181] usbcore: registered new interface driver sierra
[ 1.156768] usbserial: USB Serial support registered for Sierra USB modem
[ 1.163559] usbcore: registered new interface driver usb_serial_simple
[ 1.170085] usbserial: USB Serial support registered for carelink
[ 1.176180] usbserial: USB Serial support registered for zio
[ 1.181835] usbserial: USB Serial support registered for funsoft
[ 1.187841] usbserial: USB Serial support registered for flashloader
[ 1.194195] usbserial: USB Serial support registered for google
[ 1.200113] usbserial: USB Serial support registered for libtransistor
[ 1.206638] usbserial: USB Serial support registered for vivopay
[ 1.212645] usbserial: USB Serial support registered for moto_modem
[ 1.218917] usbserial: USB Serial support registered for motorola_tetra
[ 1.225524] usbserial: USB Serial support registered for nokia
[ 1.231357] usbserial: USB Serial support registered for novatel_gps
[ 1.237709] usbserial: USB Serial support registered for hp4x
[ 1.243458] usbserial: USB Serial support registered for suunto
[ 1.249374] usbserial: USB Serial support registered for siemens_mpi
[ 1.255737] usbcore: registered new interface driver visor
[ 1.261222] usbserial: USB Serial support registered for Handspring Visor / Palm OS
[ 1.268875] usbserial: USB Serial support registered for Sony Clie 5.0
[ 1.275401] usbserial: USB Serial support registered for Sony Clie 3.5
[ 1.281941] usbcore: registered new interface driver usb_ehset_test
[ 1.441809] usbcore: registered new interface driver usbhid
[ 1.450588] usbhid: USB HID core driver
[ 1.591110] usb_phy_generic soc@0:usbphynop1: supply vcc not found, using dummy regulator
[ 1.599967] usb_phy_generic soc@0:usbphynop1: dummy supplies not allowed for exclusive requests
[ 1.614753] usb_phy_generic soc@0:usbphynop2: supply vcc not found, using dummy regulator
[ 1.623087] usb_phy_generic soc@0:usbphynop2: dummy supplies not allowed for exclusive requests
[ 1.844214] gpio-501 (usb_rst): hogged as output/high
[ 1.998619] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 2.020156] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.025987] hub 1-0:1.0: USB hub found
%3CLINGO-SUB%20id%3D%22lingo-sub-2303001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGSM%20module%20detection%20issue%20on%20SM2S-IMX93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20am%20working%20on%20imx93%20board%20and%20i%20have%20a%20GSM%20module%20of%20sierra%20em9291%2C%20which%20is%20connected%20to%20the%20obu%20board%20using%20M.2%20slot.%20The%20device%20is%20expected%20to%20be%20detected%20as%20a%20USB%20device%2C%20but%20the%20module%20is%20not%20getting%20detected.%20It%20is%20confirmed%20that%20the%20module%20is%20working.%20I%20am%20attaching%20the%20dmesg%20received%20while%20booting%20the%20obu%20board.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%5B%200.931828%5D%20VFIO%20-%20User%20Level%20meta-driver%20version%3A%200.3%3CBR%20%2F%3E%5B%200.938331%5D%20ehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3CBR%20%2F%3E%5B%200.944887%5D%20ehci-pci%3A%20EHCI%20PCI%20platform%20driver%3CBR%20%2F%3E%5B%200.949365%5D%20ehci-platform%3A%20EHCI%20generic%20platform%20driver%3CBR%20%2F%3E%5B%200.954737%5D%20ohci_hcd%3A%20USB%201.1%20'Open'%20Host%20Controller%20(OHCI)%20Driver%3CBR%20%2F%3E%5B%200.960930%5D%20ohci-pci%3A%20OHCI%20PCI%20platform%20driver%3CBR%20%2F%3E%5B%200.965405%5D%20ohci-platform%3A%20OHCI%20generic%20platform%20driver%3CBR%20%2F%3E%5B%200.971142%5D%20usbcore%3A%20registered%20new%20interface%20driver%20uas%3CBR%20%2F%3E%5B%200.976500%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3CBR%20%2F%3E%5B%200.982570%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbserial_generic%3CBR%20%2F%3E%5B%200.989104%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20generic%3CBR%20%2F%3E%5B%200.995126%5D%20usbcore%3A%20registered%20new%20interface%20driver%20ftdi_sio%3CBR%20%2F%3E%5B%201.000867%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20FTDI%20USB%20Serial%20Device%3CBR%20%2F%3E%5B%201.008187%5D%20usbcore%3A%20registered%20new%20interface%20driver%20qcaux%3CBR%20%2F%3E%5B%201.013668%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20qcaux%3CBR%20%2F%3E%5B%201.019508%5D%20usbcore%3A%20registered%20new%20interface%20driver%20qcserial%3CBR%20%2F%3E%5B%201.025262%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Qualcomm%20USB%20modem%3CBR%20%2F%3E%5B%201.032230%5D%20usbcore%3A%20registered%20new%20interface%20driver%20sierra%3CBR%20%2F%3E%5B%201.037803%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Sierra%20USB%20modem%3CBR%20%2F%3E%5B%201.044605%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usb_serial_simple%3CBR%20%2F%3E%5B%201.051134%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20carelink%3CBR%20%2F%3E%5B%201.057225%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20zio%3CBR%20%2F%3E%5B%201.062885%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20funsoft%3CBR%20%2F%3E%5B%201.068896%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20flashloader%3CBR%20%2F%3E%5B%201.075243%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20google%3CBR%20%2F%3E%5B%201.081165%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20libtransistor%3CBR%20%2F%3E%5B%201.087688%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20vivopay%3CBR%20%2F%3E%5B%201.093694%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20moto_modem%3CBR%20%2F%3E%5B%201.099962%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20motorola_tetra%3CBR%20%2F%3E%5B%201.106578%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20nokia%3CBR%20%2F%3E%5B%201.112406%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20novatel_gps%3CBR%20%2F%3E%5B%201.118758%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20hp4x%3CBR%20%2F%3E%5B%201.124505%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20suunto%3CBR%20%2F%3E%5B%201.130430%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20siemens_mpi%3CBR%20%2F%3E%5B%201.136787%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usb_ehset_test%3CBR%20%2F%3E%5B%201.144781%5D%20bbnsm_pwrkey%2044440000.bbnsm%3Apwrkey%3A%20KEY_POWER%20without%20setting%20in%20dts%3CBR%20%2F%3E%5B%201.153199%5D%20input%3A%2044440000.bbnsm%3Apwrkey%20as%20%2Fdevices%2Fplatform%2Fsoc%400%2F44000000.bus%2F44440000.bbnsm%2F44440000.bbnsm%3Apwrkey%2Finput%2Finput0%3CBR%20%2F%3E%5B%201.168562%5D%20bbnsm_rtc%2044440000.bbnsm%3Artc%3A%20registered%20as%20rtc1%3CBR%20%2F%3E%5B%201.174625%5D%20i2c_dev%3A%20i2c%20%2Fdev%20entries%20driver%3CBR%20%2F%3E%5B%201.180869%5D%20Bluetooth%3A%20HCI%20UART%20driver%20ver%202.3%3CBR%20%2F%3E%5B%201.185332%5D%20Bluetooth%3A%20HCI%20UART%20protocol%20H4%20registered%3CBR%20%2F%3E%5B%201.190459%5D%20Bluetooth%3A%20HCI%20UART%20protocol%20BCSP%20registered%3CBR%20%2F%3E%5B%201.195781%5D%20Bluetooth%3A%20HCI%20UART%20protocol%20LL%20registered%3CBR%20%2F%3E%5B%201.200911%5D%20Bluetooth%3A%20HCI%20UART%20protocol%20ATH3K%20registered%3CBR%20%2F%3E%5B%201.206312%5D%20Bluetooth%3A%20HCI%20UART%20protocol%20Three-wire%20(H5)%20registered%3CBR%20%2F%3E%5B%201.212646%5D%20Bluetooth%3A%20HCI%20UART%20protocol%20Broadcom%20registered%3CBR%20%2F%3E%5B%201.218306%5D%20Bluetooth%3A%20HCI%20UART%20protocol%20QCA%20registered%3CBR%20%2F%3E%5B%201.224585%5D%20sdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3CBR%20%2F%3E%5B%201.230771%5D%20sdhci%3A%20Copyright(c)%20Pierre%20Ossman%3CBR%20%2F%3E%5B%201.235471%5D%20Synopsys%20Designware%20Multimedia%20Card%20Interface%20Driver%3CBR%20%2F%3E%5B%201.241788%5D%20sdhci-pltfm%3A%20SDHCI%20platform%20and%20OF%20driver%20helper%3CBR%20%2F%3E%5B%201.248334%5D%20ledtrig-cpu%3A%20registered%20to%20indicate%20activity%20on%20CPUs%3CBR%20%2F%3E%5B%201.255190%5D%20SMCCC%3A%20SOC_ID%3A%20ARCH_SOC_ID%20not%20implemented%2C%20skipping%20....%3CBR%20%2F%3E%5B%201.262002%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbhid%3CBR%20%2F%3E%5B%201.267582%5D%20usbhid%3A%20USB%20HID%20core%20driver%3CBR%20%2F%3E%5B%201.274075%5D%20cs_system_cfg%3A%20CoreSight%20Configuration%20manager%20initialised%3CBR%20%2F%3E%5B%201.279383%5D%20mmc0%3A%20SDHCI%20controller%20on%2042850000.mmc%20%5B42850000.mmc%5D%20using%20ADMA%3CBR%20%2F%3E%5B%201.281330%5D%20optee%3A%20probing%20for%20conduit%20method.%3CBR%20%2F%3E%5B%201.292295%5D%20optee%3A%20revision%203.21%20(4e322819)%3CBR%20%2F%3E%5B%201.292765%5D%20optee%3A%20dynamic%20shared%20memory%20is%20enabled%3CBR%20%2F%3E%5B%201.302169%5D%20optee%3A%20initialized%20driver%3CBR%20%2F%3E%5B%201.309028%5D%20NET%3A%20Registered%20PF_LLC%20protocol%20family%3CBR%20%2F%3E%5B%201.314219%5D%20NET%3A%20Registered%20PF_INET6%20protocol%20family%3CBR%20%2F%3E%5B%201.319851%5D%20Segment%20Routing%20with%20IPv6%3CBR%20%2F%3E%5B%201.323558%5D%20In-situ%20OAM%20(IOAM)%20with%20IPv6%3CBR%20%2F%3E%5B%201.327546%5D%20NET%3A%20Registered%20PF_PACKET%20protocol%20family%3CBR%20%2F%3E%5B%201.332736%5D%20Bluetooth%3A%20RFCOMM%20TTY%20layer%20initialized%3CBR%20%2F%3E%5B%201.337666%5D%20Bluetooth%3A%20RFCOMM%20socket%20layer%20initialized%3CBR%20%2F%3E%5B%201.342834%5D%20Bluetooth%3A%20RFCOMM%20ver%201.11%3CBR%20%2F%3E%5B%201.346599%5D%20Bluetooth%3A%20BNEP%20(Ethernet%20Emulation)%20ver%201.3%3CBR%20%2F%3E%5B%201.351905%5D%20Bluetooth%3A%20BNEP%20filters%3A%20protocol%20multicast%3CBR%20%2F%3E%5B%201.357134%5D%20Bluetooth%3A%20BNEP%20socket%20layer%20initialized%3CBR%20%2F%3E%5B%201.362102%5D%20Bluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20ver%201.2%3CBR%20%2F%3E%5B%201.368173%5D%20Bluetooth%3A%20HIDP%20socket%20layer%20initialized%3CBR%20%2F%3E%5B%201.373462%5D%208021q%3A%20802.1Q%20VLAN%20Support%20v1.8%3CBR%20%2F%3E%5B%201.377770%5D%209pnet%3A%20Installing%209P2000%20support%3CBR%20%2F%3E%5B%201.382072%5D%20tsn%20generic%20netlink%20module%20v1%20init...%3CBR%20%2F%3E%5B%201.386857%5D%20Key%20type%20dns_resolver%20registered%3CBR%20%2F%3E%5B%201.391436%5D%20Loading%20compiled-in%20X.509%20certificates%3CBR%20%2F%3E%5B%201.401620%5D%20mmc0%3A%20new%20HS400%20Enhanced%20strobe%20MMC%20card%20at%20address%200001%3CBR%20%2F%3E%5B%201.406271%5D%20usb_phy_generic%20soc%400%3Ausbphynop1%3A%20supply%20vcc%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%201.412543%5D%20mmcblk0%3A%20mmc0%3A0001%20IB2916%2014.6%20GiB%3CBR%20%2F%3E%5B%201.416324%5D%20usb_phy_generic%20soc%400%3Ausbphynop1%3A%20dummy%20supplies%20not%20allowed%20for%20exclusive%20requests%3CBR%20%2F%3E%5B%201.429790%5D%20usb_phy_generic%20soc%400%3Ausbphynop2%3A%20supply%20vcc%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%201.429826%5D%20mmcblk0boot0%3A%20mmc0%3A0001%20IB2916%204.00%20MiB%3CBR%20%2F%3E%5B%201.438122%5D%20usb_phy_generic%20soc%400%3Ausbphynop2%3A%20dummy%20supplies%20not%20allowed%20for%20exclusive%20requests%3CBR%20%2F%3E%5B%201.444228%5D%20mmcblk0boot1%3A%20mmc0%3A0001%20IB2916%204.00%20MiB%3CBR%20%2F%3E%5B%201.457681%5D%20mmcblk0rpmb%3A%20mmc0%3A0001%20IB2916%204.00%20MiB%2C%20chardev%20(510%3A0)%3CBR%20%2F%3E%5B%201.462392%5D%20fsl_lpspi%2042550000.spi%3A%20dma%20setup%20error%20-19%2C%20use%20pio%3CBR%20%2F%3E%5B%201.471555%5D%20fsl_lpspi%2042700000.spi%3A%20dma%20setup%20error%20-19%2C%20use%20pio%3CBR%20%2F%3E%5B%201.481628%5D%20sdhci-esdhc-imx%2042860000.mmc%3A%20Got%20CD%20GPIO%3CBR%20%2F%3E%5B%201.483514%5D%20rtc-rs5c372%200-0032%3A%20r2223x%20found%2C%2024hr%3CBR%20%2F%3E%5B%201.491776%5D%20rtc-rs5c372%200-0032%3A%20eco%20mode%20enabled%3CBR%20%2F%3E%5B%201.497022%5D%20rtc-rs5c372%200-0032%3A%20rtc%20oscillator%20interruption%20detected.%20Please%20reset%20the%20rtc%20clock.%3CBR%20%2F%3E%5B%201.506032%5D%20rtc-rs5c372%200-0032%3A%20registered%20as%20rtc0%3CBR%20%2F%3E%5B%201.511293%5D%20rtc-rs5c372%200-0032%3A%20rtc%20oscillator%20interruption%20detected.%20Please%20reset%20the%20rtc%20clock.%3CBR%20%2F%3E%5B%201.518103%5D%20mmc1%3A%20SDHCI%20controller%20on%2042860000.mmc%20%5B42860000.mmc%5D%20using%20ADMA%3CBR%20%2F%3E%5B%201.520159%5D%20rtc-rs5c372%200-0032%3A%20hctosys%3A%20unable%20to%20read%20the%20hardware%20clock%3CBR%20%2F%3E%5B%201.534862%5D%20i2c%20i2c-0%3A%20LPI2C%20adapter%20registered%3CBR%20%2F%3E%5B%201.540762%5D%20VCC_SOC_0V8%3A%20Bringing%20900000uV%20into%20800000-800000uV%3CBR%20%2F%3E%5B%201.550695%5D%20rn5t618%201-0030%3A%20running%20in%20single%2Fmaster%20mode%3CBR%20%2F%3E%5B%201.556229%5D%20i2c%20i2c-1%3A%20LPI2C%20adapter%20registered%3CBR%20%2F%3E%5B%201.561451%5D%20i2c%20i2c-2%3A%20LPI2C%20adapter%20registered%3CBR%20%2F%3E%5B%201.567013%5D%20pca953x%204-0022%3A%20supply%20vcc%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%201.573737%5D%20pca953x%204-0022%3A%20using%20AI%3CBR%20%2F%3E%5B%201.578406%5D%20gpio-488%20(boot_sel0)%3A%20hogged%20as%20input%3CBR%20%2F%3E%5B%201.583227%5D%20gpio-489%20(boot_sel1)%3A%20hogged%20as%20input%3CBR%20%2F%3E%5B%201.588029%5D%20gpio-490%20(boot_sel2)%3A%20hogged%20as%20input%3CBR%20%2F%3E%5B%201.593032%5D%20gpio-498%20(wifi_en)%3A%20hogged%20as%20output%2Flow%3CBR%20%2F%3E%5B%201.598179%5D%20gpio-499%20(gbe0_rst)%3A%20hogged%20as%20output%2Fhigh%3CBR%20%2F%3E%5B%201.603518%5D%20gpio-500%20(gbe1_rst)%3A%20hogged%20as%20output%2Fhigh%3CBR%20%2F%3E%5B%201.608840%5D%20gpio-501%20(usb_rst)%3A%20hogged%20as%20output%2Flow%3CBR%20%2F%3E%5B%201.614112%5D%20i2c%20i2c-4%3A%20LPI2C%20adapter%20registered%3CBR%20%2F%3E%5B%201.618686%5D%20mmc1%3A%20host%20does%20not%20support%20reading%20read-only%20switch%2C%20assuming%20write-enable%3CBR%20%2F%3E%5B%201.624451%5D%20pps%20pps0%3A%20new%20PPS%20source%20ptp0%3CBR%20%2F%3E%5B%201.634301%5D%20fec%2042890000.ethernet%20eth0%3A%20registered%20PHC%20device%200%3CBR%20%2F%3E%5B%201.641039%5D%20imx-dwmac%20428a0000.ethernet%3A%20IRQ%20eth_lpi%20not%20found%3CBR%20%2F%3E%5B%201.647260%5D%20imx-dwmac%20428a0000.ethernet%3A%20User%20ID%3A%200x10%2C%20Synopsys%20ID%3A%200x52%3CBR%20%2F%3E%5B%201.654155%5D%20imx-dwmac%20428a0000.ethernet%3A%20DWMAC4%2F5%3CBR%20%2F%3E%5B%201.659958%5D%20imx-dwmac%20428a0000.ethernet%3A%20DMA%20HW%20capability%20register%20supported%3CBR%20%2F%3E%5B%201.667100%5D%20imx-dwmac%20428a0000.ethernet%3A%20RX%20Checksum%20Offload%20Engine%20supported%3CBR%20%2F%3E%5B%201.674235%5D%20imx-dwmac%20428a0000.ethernet%3A%20TX%20Checksum%20insertion%20supported%3CBR%20%2F%3E%5B%201.680926%5D%20imx-dwmac%20428a0000.ethernet%3A%20Wake-Up%20On%20Lan%20supported%3CBR%20%2F%3E%5B%201.687072%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enable%20RX%20Mitigation%20via%20HW%20Watchdog%20Timer%3CBR%20%2F%3E%5B%201.694737%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabled%20L3L4%20Flow%20TC%20(entries%3D8)%3CBR%20%2F%3E%5B%201.701520%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabled%20RFS%20Flow%20TC%20(entries%3D8)%3CBR%20%2F%3E%5B%201.708233%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabling%20HW%20TC%20(entries%3D256%2C%20max_off%3D256)%3CBR%20%2F%3E%5B%201.715805%5D%20imx-dwmac%20428a0000.ethernet%3A%20Using%2032%20bits%20DMA%20width%3CBR%20%2F%3E%5B%201.721914%5D%20mmc1%3A%20new%20ultra%20high%20speed%20SDR104%20SDHC%20card%20at%20address%20aaaa%3CBR%20%2F%3E%5B%201.727699%5D%20ci_hdrc%20ci_hdrc.0%3A%20EHCI%20Host%20Controller%3CBR%20%2F%3E%5B%201.729047%5D%20mmcblk1%3A%20mmc1%3Aaaaa%20SK32G%2029.7%20GiB%3CBR%20%2F%3E%5B%201.733484%5D%20ci_hdrc%20ci_hdrc.0%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3CBR%20%2F%3E%5B%201.745048%5D%20mmcblk1%3A%20p1%20p2%3CBR%20%2F%3E%5B%201.760163%5D%20ci_hdrc%20ci_hdrc.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3CBR%20%2F%3E%5B%201.765999%5D%20hub%201-0%3A1.0%3A%20USB%20hub%20found%3CBR%20%2F%3E%5B%201.769782%5D%20hub%201-0%3A1.0%3A%201%20port%20detected%3CBR%20%2F%3E%5B%201.777856%5D%20ci_hdrc%20ci_hdrc.1%3A%20EHCI%20Host%20Controller%3CBR%20%2F%3E%5B%201.782766%5D%20ci_hdrc%20ci_hdrc.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%202%3CBR%20%2F%3E%5B%201.804160%5D%20ci_hdrc%20ci_hdrc.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3CBR%20%2F%3E%5B%201.810031%5D%20hub%202-0%3A1.0%3A%20USB%20hub%20found%3CBR%20%2F%3E%5B%201.813807%5D%20hub%202-0%3A1.0%3A%201%20port%20detected%3CBR%20%2F%3E%5B%201.819619%5D%20cfg80211%3A%20Loading%20compiled-in%20X.509%20certificates%20for%20regulatory%20database%3CBR%20%2F%3E%5B%201.828751%5D%20cfg80211%3A%20Loaded%20X.509%20cert%20'sforshee%3A%2000b28ddf47aef9cea7'%3CBR%20%2F%3E%5B%201.835382%5D%20platform%20regulatory.0%3A%20Direct%20firmware%20load%20for%20regulatory.db%20failed%20with%20error%20-2%3CBR%20%2F%3E%5B%201.836751%5D%20ALSA%20device%20list%3A%3CBR%20%2F%3E%5B%201.844007%5D%20platform%20regulatory.0%3A%20Falling%20back%20to%20sysfs%20fallback%20for%3A%20regulatory.db%3CBR%20%2F%3E%5B%201.847023%5D%20No%20soundcards%20found.%3CBR%20%2F%3E%5B%201.872310%5D%20EXT4-fs%20(mmcblk1p2)%3A%20mounted%20filesystem%20with%20ordered%20data%20mode.%20Opts%3A%20(null).%20Quota%20mode%3A%20none.%3CBR%20%2F%3E%5B%201.882126%5D%20VFS%3A%20Mounted%20root%20(ext4%20filesystem)%20on%20device%20179%3A98.%3CBR%20%2F%3E%5B%201.888794%5D%20devtmpfs%3A%20mounted%3CBR%20%2F%3E%5B%201.893640%5D%20Freeing%20unused%20kernel%20memory%3A%202816K%3CBR%20%2F%3E%5B%201.898295%5D%20Run%20%2Fsbin%2Finit%20as%20init%20process%3CBR%20%2F%3E%5B%202.028179%5D%20usb%201-1%3A%20new%20full-speed%20USB%20device%20number%202%20using%20ci_hdrc%3CBR%20%2F%3E%5B%202.040991%5D%20systemd%5B1%5D%3A%20System%20time%20before%20build%20time%2C%20advancing%20clock.%3CBR%20%2F%3E%5B%202.062635%5D%20systemd%5B1%5D%3A%20systemd%20250.5%2B%20running%20in%20system%20mode%20(%2BPAM%20-AUDIT%20-SELINUX%20-APPARMOR%20%2BIMA%20-SMACK%20%2BSECCOMP%20-GCRYPT%20-GNUTLS%20-OPENSSL%20%2BACL%20%2BBLKID%20-CURL%20-ELFUTILS%20-FIDO2%20-IDN2%20-IDN%20-IPTC%20%2BKMOD%20-LIBCRYPTSETUP%20%2BLIBFDISK%20-PCRE2%20-PWQUALITY%20-P11KIT%20-QRENCODE%20-BZIP2%20-LZ4%20-XZ%20-ZLIB%20%2BZSTD%20-BPF_FRAMEWORK%20-XKBCOMMON%20%2BUTMP%20%2BSYSVINIT%20default-hierarchy%3Dhybrid)%3CBR%20%2F%3E%5B%202.093842%5D%20usb%202-1%3A%20new%20high-speed%20USB%20device%20number%202%20using%20ci_hdrc%3CBR%20%2F%3E%5B%202.096607%5D%20systemd%5B1%5D%3A%20Detected%20architecture%20arm64.%3C%2FP%3E%3CP%3EWelcome%20to%20Poky%20(Yocto%20Project%20Reference%20Distro)%204.0.4%20(kirkstone)!%3C%2FP%3E%3CP%3E%5B%202.172996%5D%20systemd%5B1%5D%3A%20Hostname%20set%20to%20%3CSM2S-IMX93%3E.%3CBR%20%2F%3E%5B%202.199166%5D%20usb%201-1%3A%20not%20running%20at%20top%20speed%3B%20connect%20to%20a%20high%20speed%20hub%3CBR%20%2F%3E%5B%202.244999%5D%20systemd-sysv-generator%5B162%5D%3A%20SysV%20service%20'%2Fetc%2Finit.d%2Fcmdline-keyboard.sh'%20lacks%20a%20native%20systemd%20unit%20file.%20Automatically%20generating%20a%20unit%20file%20for%20compatibility.%20Please%20update%20package%20to%20include%20a%20native%20systemd%20unit%20file%2C%20in%20order%20to%20make%20it%20more%20safe%20and%20robust.%3CBR%20%2F%3E%5B%202.271158%5D%20hub%202-1%3A1.0%3A%20USB%20hub%20found%3CBR%20%2F%3E%5B%202.275119%5D%20hub%202-1%3A1.0%3A%204%20ports%20detected%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSM2S-IMX93%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2303001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GSM%20module%20detection%20issue%20on%20SM2S-IMX93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EI%20confirm%20that%20the%20module%20is%20working%20but%20there%20is%20no%20driver%20for%20you%20GSM%2C%20so%20Adapt%20your%20driver%20with%20the%20latest%20BSP.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eregards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GSM%20module%20detection%20issue%20on%20SM2S-IMX93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%2C%3CBR%20%2F%3E%3CBR%20%2F%3EAs%20you%20suggested%20%2C%20I%20added%20the%20support%20for%20sierra%20em929x%20in%20my%20qcserial.c%20and%20qmi_wwan.c.%20Now%20this%20is%20the%20dmesg%20which%20i%20get.%20I%20am%20also%20attaching%20the%20driver%20files%20which%20i%20got%20from%20sierra%20official%20website.%3CBR%20%2F%3E%3CBR%20%2F%3E%5B%200.412001%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbfs%3CBR%20%2F%3E%5B%200.417403%5D%20usbcore%3A%20registered%20new%20interface%20driver%20hub%3CBR%20%2F%3E%5B%200.422531%5D%20usbcore%3A%20registered%20new%20device%20driver%20usb%3CBR%20%2F%3E%5B%200.947802%5D%20usbcore%3A%20registered%20new%20interface%20driver%20asix%3CBR%20%2F%3E%5B%200.953237%5D%20usbcore%3A%20registered%20new%20interface%20driver%20ax88179_178a%3CBR%20%2F%3E%5B%200.959343%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_ether%3CBR%20%2F%3E%5B%200.965189%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_eem%3CBR%20%2F%3E%5B%200.970862%5D%20usbcore%3A%20registered%20new%20interface%20driver%20net1080%3CBR%20%2F%3E%5B%200.976554%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_subset%3CBR%20%2F%3E%5B%200.982493%5D%20usbcore%3A%20registered%20new%20interface%20driver%20zaurus%3CBR%20%2F%3E%5B%200.988093%5D%20usbcore%3A%20registered%20new%20interface%20driver%20sierra_net%3CBR%20%2F%3E%5B%200.994025%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_ncm%3CBR%20%2F%3E%5B%200.999694%5D%20usbcore%3A%20registered%20new%20interface%20driver%20qmi_wwan%3CBR%20%2F%3E%5B%201.005443%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_mbim%3CBR%20%2F%3E%5B%201.018389%5D%20ehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3CBR%20%2F%3E%5B%201.034796%5D%20ohci_hcd%3A%20USB%201.1%20'Open'%20Host%20Controller%20(OHCI)%20Driver%3CBR%20%2F%3E%5B%201.051077%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_acm%3CBR%20%2F%3E%5B%201.056733%5D%20cdc_acm%3A%20USB%20Abstract%20Control%20Model%20driver%20for%20USB%20modems%20and%20ISDN%20adapters%3CBR%20%2F%3E%5B%201.064752%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_wdm%3CBR%20%2F%3E%5B%201.070600%5D%20usbcore%3A%20registered%20new%20interface%20driver%20uas%3CBR%20%2F%3E%5B%201.075953%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3CBR%20%2F%3E%5B%201.082007%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbserial_generic%3CBR%20%2F%3E%5B%201.088535%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20generic%3CBR%20%2F%3E%5B%201.094555%5D%20usbcore%3A%20registered%20new%20interface%20driver%20ftdi_sio%3CBR%20%2F%3E%5B%201.100301%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20FTDI%20USB%20Serial%20Device%3CBR%20%2F%3E%5B%201.107612%5D%20usbcore%3A%20registered%20new%20interface%20driver%20option%3CBR%20%2F%3E%5B%201.113189%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20GSM%20modem%20(1-port)%3CBR%20%2F%3E%5B%201.120185%5D%20usbcore%3A%20registered%20new%20interface%20driver%20qcaux%3CBR%20%2F%3E%5B%201.125668%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20qcaux%3CBR%20%2F%3E%5B%201.131506%5D%20usbcore%3A%20registered%20new%20interface%20driver%20qcserial%3CBR%20%2F%3E%5B%201.137254%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Qualcomm%20USB%20modem%3CBR%20%2F%3E%5B%201.144214%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Qualcomm%20USB%20modem%3CBR%20%2F%3E%5B%201.151181%5D%20usbcore%3A%20registered%20new%20interface%20driver%20sierra%3CBR%20%2F%3E%5B%201.156768%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Sierra%20USB%20modem%3CBR%20%2F%3E%5B%201.163559%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usb_serial_simple%3CBR%20%2F%3E%5B%201.170085%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20carelink%3CBR%20%2F%3E%5B%201.176180%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20zio%3CBR%20%2F%3E%5B%201.181835%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20funsoft%3CBR%20%2F%3E%5B%201.187841%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20flashloader%3CBR%20%2F%3E%5B%201.194195%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20google%3CBR%20%2F%3E%5B%201.200113%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20libtransistor%3CBR%20%2F%3E%5B%201.206638%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20vivopay%3CBR%20%2F%3E%5B%201.212645%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20moto_modem%3CBR%20%2F%3E%5B%201.218917%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20motorola_tetra%3CBR%20%2F%3E%5B%201.225524%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20nokia%3CBR%20%2F%3E%5B%201.231357%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20novatel_gps%3CBR%20%2F%3E%5B%201.237709%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20hp4x%3CBR%20%2F%3E%5B%201.243458%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20suunto%3CBR%20%2F%3E%5B%201.249374%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20siemens_mpi%3CBR%20%2F%3E%5B%201.255737%5D%20usbcore%3A%20registered%20new%20interface%20driver%20visor%3CBR%20%2F%3E%5B%201.261222%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Handspring%20Visor%20%2F%20Palm%20OS%3CBR%20%2F%3E%5B%201.268875%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Sony%20Clie%205.0%3CBR%20%2F%3E%5B%201.275401%5D%20usbserial%3A%20USB%20Serial%20support%20registered%20for%20Sony%20Clie%203.5%3CBR%20%2F%3E%5B%201.281941%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usb_ehset_test%3CBR%20%2F%3E%5B%201.441809%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbhid%3CBR%20%2F%3E%5B%201.450588%5D%20usbhid%3A%20USB%20HID%20core%20driver%3CBR%20%2F%3E%5B%201.591110%5D%20usb_phy_generic%20soc%400%3Ausbphynop1%3A%20supply%20vcc%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%201.599967%5D%20usb_phy_generic%20soc%400%3Ausbphynop1%3A%20dummy%20supplies%20not%20allowed%20for%20exclusive%20requests%3CBR%20%2F%3E%5B%201.614753%5D%20usb_phy_generic%20soc%400%3Ausbphynop2%3A%20supply%20vcc%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%201.623087%5D%20usb_phy_generic%20soc%400%3Ausbphynop2%3A%20dummy%20supplies%20not%20allowed%20for%20exclusive%20requests%3CBR%20%2F%3E%5B%201.844214%5D%20gpio-501%20(usb_rst)%3A%20hogged%20as%20output%2Fhigh%3CBR%20%2F%3E%5B%201.998619%5D%20ci_hdrc%20ci_hdrc.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3CBR%20%2F%3E%5B%202.020156%5D%20ci_hdrc%20ci_hdrc.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3CBR%20%2F%3E%5B%202.025987%5D%20hub%201-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3C%2FLINGO-BODY%3E
