GL_INVALID_OPERATION error, when doing multisample framebuffer to multisample EGL Surface blitting
mallibeerala
I am doing multisample framebuffer to multisample EGL Surface blitting using Opengl ES in my I.MX8QM Eval board and I am getting error as "GL_INVALID_OPERATION". Below are the steps I did.
  • FrameBufferObject created with multisampled renderbuffer attached as  glRenderbufferStorageMultisample(GL_RENDERBUFFER, 4, GL_RGBA8, width,height); and drawing in to FBO.
  • When using glBlitFramebuffer to render from FBO in to Default Framebuffer ,it gives GL_INVALID_OPERATION error when EGL window surface is created with attributes:
    • EGL_SAMPLES = 4
    • EGL_RED_SIZE = 8
    • EGL_GREEN_SIZE = 8
    • EGL_BLUE_SIZE = 8
    • EGL_ALPHA_SIZE = 8
  • When EGL Surface  is created with EGL_SAMPLES = 0 glBlitFramebuffer draws in to default framebuffer correctly.
    Source and Destination rectangles are  exactly same size in the glBlitFramebuffer.
AldoG
This kind of use case is forbidden in OpenGL ES, you cannot resolve (blit) from multisampled buffer to a multisampled buffer.
As specified in the documentation:
https://registry.khronos.org/OpenGL-Refpages/es3.0/html/glBlitFramebuffer.xhtml
GL_INVALID_OPERATION is generated if the value of GL_SAMPLE_BUFFERS for the draw buffer is greater than zero.
Best regards/Saludos,
Aldo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2368409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGL_INVALID_OPERATION%20error%2C%20when%20doing%20multisample%20framebuffer%20to%20multisample%20EGL%20Surface%20blitting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2368409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20am%20doing%26nbsp%3Bmultisample%20framebuffer%20to%20multisample%20EGL%20Surface%20blitting%20using%20Opengl%20ES%20in%20my%20I.MX8QM%20Eval%20board%20and%20I%20am%20getting%20error%20as%20%22%3CSPAN%3E%3CSTRONG%3EGL_INVALID_OPERATION%3C%2FSTRONG%3E%3C%2FSPAN%3E%22.%20Below%20are%20the%20steps%20I%20did.%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20align%3D%22left%22%3E%3CSPAN%3EFrameBufferObject%20%3C%2FSPAN%3E%3CSPAN%3Ecreated%20%3C%2FSPAN%3E%3CSPAN%3Ewith%20multisampled%20renderbuffer%20attached%20%3C%2FSPAN%3E%3CSPAN%3Eas%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3CSTRONG%3EglRenderbufferStorageMultisample%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E(GL_RENDERBUFFER%2C%204%2C%20GL_RGBA8%2C%20width%2Cheight)%3B%20and%20drawing%20in%20to%20FBO.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%3CSPAN%3EWhen%20using%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CSTRONG%3EglBlitFramebuffer%20%3C%2FSTRONG%3Eto%20render%20from%20FBO%20in%20to%20Default%20Framebuffer%20%2Cit%20gives%20%3CSTRONG%3EGL_INVALID_OPERATION%3C%2FSTRONG%3E%26nbsp%3Berror%20when%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3EEGL%20window%20surface%20is%20created%20with%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3Eattributes%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CP%20align%3D%22left%22%3EEGL_SAMPLES%20%3D%204%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20align%3D%22left%22%3EEGL_RED_SIZE%20%3D%208%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20align%3D%22left%22%3EEGL_GREEN_SIZE%20%3D%208%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20align%3D%22left%22%3EEGL_BLUE_SIZE%20%3D%208%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20align%3D%22left%22%3EEGL_ALPHA_SIZE%20%3D%208%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%3CSPAN%3EWhen%20EGL%20Surface%26nbsp%3B%20is%20created%20with%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EEGL_SAMPLES%20%3D%200%26nbsp%3B%3CSPAN%3E%3CSTRONG%3EglBlitFramebuffer%20%3C%2FSTRONG%3Edraws%20in%20to%20default%20framebuffer%20correctly.%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3ENote%3A%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3ESource%20and%20Destination%20rectangles%20are%26nbsp%3B%20exactly%20same%20size%20in%20the%26nbsp%3B%3CSTRONG%3EglBlitFramebuffer%3C%2FSTRONG%3E.%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GL_INVALID_OPERATION%20error%2C%20when%20doing%20multisample%20framebuffer%20to%20multisample%20EGL%20Surface%20blitti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThis%20kind%20of%20use%20case%20is%20forbidden%20in%20OpenGL%20ES%2C%20you%20cannot%20resolve%20(blit)%20from%20multisampled%20buffer%20to%20a%20multisampled%20buffer.%3CBR%20%2F%3E%3CBR%20%2F%3EAs%20specified%20in%20the%20documentation%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fregistry.khronos.org%2FOpenGL-Refpages%2Fes3.0%2Fhtml%2FglBlitFramebuffer.xhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fregistry.khronos.org%2FOpenGL-Refpages%2Fes3.0%2Fhtml%2FglBlitFramebuffer.xhtml%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3EGL_INVALID_OPERATION%20is%20generated%20if%20the%20value%20of%20GL_SAMPLE_BUFFERS%20for%20the%20draw%20buffer%20is%20greater%20than%20zero.%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%2FSaludos%2C%3CBR%20%2F%3EAldo.%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
