GFX Ring Test Failure on AMDGPU(E9171)
1,740 次查看
Ganesh3955
I am working on the i.MX95 DevKit (8GB) with AMDGPU (E9171) configured as a PCIe endpoint connected through an x2 interface.
On the i.MX95, there is no 64-bit prefetchable range present by default. However, for this AMDGPU to function, it requires a minimum 8GB 64-bit prefetchable PCIe range.
To address this, I added a custom range in the device tree (imx95-ig61d-prgwd.dts) as shown below:
&pcie0 {
       pinctrl-0 = <&pinctrl_pcie0>;
       pinctrl-names = "default";
      fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_OUTPUT>;
      reset-gpio = <&i2c4_gpio_expander_20 6 GPIO_ACTIVE_LOW>;
      vpcie-supply = <&reg_pcie0>;
      status = "ok";
      ranges = <0x81000000 0x0 0x00000000 0x0 0x6ff00000 0 0x00100000>,//IO ports- default
     <0x82000000 0x0 0x00000000 0x9 0x00000000 0 0x10000000>, //32 bit non-prefetchable -        default
     <0xC2000000 0x0 0x10000000 0x9 0x10000000 0x1 0x00000000>; //64 bit prefetchable -             custom added
I am able to assign 4GB as the maximum size for the custom range. If I increase it beyond that, the driver gets stuck at 'Chained IB support enabled!'
After increasing the range size to 4GB driver goes further and gfx test fails
I found a similar issue in the forum stating that fsl_pamu should be disabled, but in my case it is already disabled in the kernel 'CONFIG_FSL_PAMU=n'
Reference:
https://community.nxp.com/t5/T-Series/T2080-PCIe-transfer-error-with-PAMU-enabled/m-p/1310923
How can I solve this problem? Please find the test log below.
6 回复数
1,700 次查看
Zhiming_Liu
Hi @Ganesh3955
1. I confirmed with internal team before: The i.MX95 features two independent PCIe Gen 3 x1 controllers that cannot be aggregated into a single x2 link; your boot logs also clearly show that the negotiation result for this link is “PCIe Gen 3 x1 link up.”
2. According to lspci -vvv, the maximum supported size for BAR0 under Resizable BAR is only 4GB, not 8GB. Your log already states this clearly: BAR 0: current size: 256MB, supported: 256MB 512MB 1GB 2GB 4GB.
3. As mentioned in the discussions regarding amd-gfx, amdgpu attempts to set the GPU's BAR0 to the largest possible value; if there is insufficient space or the device does not support a larger size, it falls back.
https://lists.freedesktop.org/archives/amd-gfx/2020-December/057339.html
Based on the current logs, it’s not that amdgpu doesn’t want to expand, but rather that the contiguous 64-bit prefetchable space following the RC is insufficient, non-contiguous, or does not meet alignment requirements. The starting address of your current window is 0x10000000 (PCI-side), which is not a 4GB naturally aligned boundary.
Zhiming
1,686 次查看
Ganesh3955
HI @Zhiming_Liu
Thank you for quick reply,
Can you suggest me a proper 64-bit prefetchable space with 8GB size for this PCIe BAR
Ganesh
1,675 次查看
Zhiming_Liu
Hi @Ganesh3955
Confirmed with PCIE owner, the supported size of BAR0 can only up to 4GB size.
Zhiming
1,649 次查看
Ganesh3955
Hi @Zhiming_Liu
Is this limitation is for i.MX95 only or for T2080 processor as well? Please confirm how much of address space can be allocated in T2080 processor.
Ganesh
1,613 次查看
Zhiming_Liu
Hi @Ganesh3955
This specifically refers to the i.MX95.
Zhiming
1,610 次查看
Ganesh3955
Hi @Zhiming_Liu
Thank you for your reply,
How i can continue my testing with E9171 GPU using i.MX95 board. And why GFX ring test is failing, is there any solution for this?
Ganesh
%3CLINGO-SUB%20id%3D%22lingo-sub-2356651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAMDGPU(E9171)%20GFX%20Ring%20%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20i.MX95%20DevKit%EF%BC%888GB%EF%BC%89%EF%BC%8CAMDGPU%EF%BC%88E9171%EF%BC%89%E9%85%8D%E7%BD%AE%E4%B8%BA%20PCIe%20%E7%AB%AF%E7%82%B9%EF%BC%8C%E9%80%9A%E8%BF%87%20x2%20%E6%8E%A5%E5%8F%A3%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%20i.MX95%20%E4%B8%8A%EF%BC%8C%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E6%B2%A1%E6%9C%89%2064%20%E4%BD%8D%E5%8F%AF%E9%A2%84%E5%8F%96%E8%8C%83%E5%9B%B4%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%A6%81%E4%BD%BF%20AMDGPU%20%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%87%B3%E5%B0%91%E9%9C%80%E8%A6%81%208GB%2064%20%E4%BD%8D%E5%8F%AF%E9%A2%84%E5%8F%96%20PCIe%20%E8%8C%83%E5%9B%B4%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E4%BA%86%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%9C%A8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%B8%AA%E8%87%AA%E5%AE%9A%E4%B9%89%E8%8C%83%E5%9B%B4%20(imx95-ig61d-prgwd.dts)%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%26amp%3B%20pcie0%3CBR%20%2F%3E%20%7Bpinctrl-0%20%3D%20%26lt%3B%20%26amp%3B%20pinctrl_pcie0%20%26gt%3B%EF%BC%9Bp%3CBR%20%2F%3E%20inctrl-nam%20es%20%3D%20%22%20%E9%BB%98%E8%AE%A4%3CBR%20%2F%3E%20%22%EF%BC%9Bfsl%EF%BC%8Crefclk-pad-mode%20%3D%3CIMX8_PCIE_REFCLK_PAD_OUTPUT%3E%20%3CBR%20%2F%3E%EF%BC%9Breset-gpio%20%3D%20%26lt%3B%20%26amp%3B%20i2c4_gpio_expander_20%206%20GPIO_ACTIVE_LOW%20%26gt%3B%3B%3CBR%20%2F%3E%20vpcie-supply%20%3D%20%26lt%3B%20%26amp%3B%20reg_pcie0%20%26gt%3B%3B%3CBR%20%2F%3E%20%E7%8A%B6%E6%80%81%20%3D%20%22%20ok%20%22%3B%3CBR%20%2F%3E%20%E8%8C%83%E5%9B%B4%20%3D%20%26lt%3B%200x81000000%200x0%26lt%3B0x81000000%200x0%200x00000000%200x0%200x6ff00000%200%200x00100000%26gt%3B%200x00000000%200x0%200x0%200x6ff00000%200%200%200x0000000%200%200x0000000%200%200x0%200x0000000%200%3CBR%20%2F%3E%26lt%3B0x82000000%200x0%200x00000000%200x9%200x00000000%200%200x10000000%26gt%3B%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x000000%200%200x%20%26gt%3B%20%26lt%3B%26gt%3B%2C%20%2F%2F32%3CBR%20%2F%3E%26lt%3B0xC2000000%200x0%200x10000000%200x9%200x10000000%200x1%200x00000000%26gt%3B%20%E4%BD%8D%E4%B8%8D%E5%8F%AF%E9%A2%84%E5%8F%96-%E9%BB%98%E8%AE%A4%3B%20%2F%2F64%3CBR%20%2F%3E%20%E4%BD%8D%E5%8F%AF%E9%A2%84%E5%8F%96-%E8%87%AA%E5%AE%9A%E4%B9%89%7D%3B%3C%2FIMX8_PCIE_REFCLK_PAD_OUTPUT%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%86%204GB%20%E6%8C%87%E5%AE%9A%E4%B8%BA%E8%87%AA%E5%AE%9A%E4%B9%89%E8%8C%83%E5%9B%B4%E7%9A%84%E6%9C%80%E5%A4%A7%E5%A4%A7%E5%B0%8F%E3%80%82%E5%A6%82%E6%9E%9C%E8%B6%85%E8%BF%87%E8%BF%99%E4%B8%AA%E5%80%BC%EF%BC%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B0%B1%E4%BC%9A%E5%8D%A1%E5%9C%A8%20%22%E5%B7%B2%E5%90%AF%E7%94%A8%E9%93%BE%E5%BC%8F%20IB%20%E6%94%AF%E6%8C%81%EF%BC%81%22%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E5%B0%86%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%8C%83%E5%9B%B4%E5%A4%A7%E5%B0%8F%E5%A2%9E%E5%8A%A0%E5%88%B0%204GB%20%E4%B9%8B%E5%90%8E%20gfx%3CBR%20%2F%3E%20%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%E5%90%8E%EF%BC%8C%20%E6%88%91%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%AD%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%8C%87%E5%87%BA%E5%BA%94%E8%AF%A5%E7%A6%81%E7%94%A8%20fsl_pamu%EF%BC%8C%E4%BD%86%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%E5%AE%83%E5%B7%B2%E7%BB%8F%E5%9C%A8%E5%86%85%E6%A0%B8%20%E2%80%9Cconfig_fsl_pamu%3Dn%E2%80%9D%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FT-Series%2FT2080-PCIe-transfer-error-with-PAMU-enabled%2Fm-p%2F1310923%22%20target%3D%22_blank%22%3E%E4%B8%AD%E8%A2%AB%E7%A6%81%E7%94%A8%E4%BA%86%E3%80%82%E5%8F%82%E8%80%83%EF%BC%9Ahttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FT-Series%2FT2080-PCIe-transfer-error-with-PAMU-enabled%2Fm-p%2F1310923%3C%2FA%3E%3CBR%20%2F%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%E8%AF%B7%E6%9F%A5%E7%9C%8B%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%B5%8B%E8%AF%95%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2357089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GFX%20Ring%20Test%20Failure%20on%20AMDGPU(E9171)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262041%22%20target%3D%22_blank%22%3E%40Ganesh3955%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%BB%8F%E4%B8%8E%20PCIE%20%E6%89%80%E6%9C%89%E8%80%85%E7%A1%AE%E8%AE%A4%EF%BC%8C%E6%94%AF%E6%8C%81%E7%9A%84%20BAR0%20%E5%A4%A7%E5%B0%8F%E6%9C%80%E5%A4%9A%E5%8F%AA%E8%83%BD%E8%BE%BE%E5%88%B0%204GB%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GFX%20Ring%20Test%20Failure%20on%20AMDGPU(E9171)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%EF%BC%8C%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E5%90%A6%E4%B8%BA%E6%88%91%E6%8E%A8%E8%8D%90%E4%B8%80%E4%B8%AA%E5%90%88%E9%80%82%E7%9A%84%2064%20%E4%BD%8D%E9%A2%84%E5%8F%96%E7%A9%BA%E9%97%B4%EF%BC%8C%E5%A4%A7%E5%B0%8F%E4%B8%BA%208GB%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%AD%A4%20PCIe%20BAR%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%9C%80%E4%BD%B3%E5%9B%9E%E5%A4%8D%EF%BC%8C%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EGanesh%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GFX%20Ring%20Test%20Failure%20on%20AMDGPU(E9171)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262041%22%20target%3D%22_blank%22%3E%40Ganesh3955%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E1.%E6%88%91%E4%B9%8B%E5%89%8D%3CSTRONG%3E%E5%90%91%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E8%AF%81%E5%AE%9E%EF%BC%9Ai.MX95%E5%85%B7%E6%9C%89%E4%B8%A4%E4%B8%AA%E7%8B%AC%E7%AB%8B%E7%9A%84PCIe%20Gen%203%20x1%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C%E6%97%A0%E6%B3%95%E8%81%9A%E5%90%88%E6%88%90%E5%8D%95%E4%B8%AAx2%E9%93%BE%E8%B7%AF%3C%2FSTRONG%3E%EF%BC%9B%E6%82%A8%E7%9A%84%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E8%BF%98%E6%B8%85%E6%A5%9A%E5%9C%B0%E6%98%BE%E7%A4%BA%E8%AF%A5%E9%93%BE%E8%B7%AF%E7%9A%84%E5%8D%8F%E5%95%86%E7%BB%93%E6%9E%9C%E6%98%AF%20%E2%80%9CPCIe%20Gen%203%20x1%E9%93%BE%E8%B7%AF%E5%90%AF%E5%8A%A8%E2%80%9D%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%E6%A0%B9%E6%8D%AE%3CSTRONG%3Elspci%20-vvv%3C%2FSTRONG%3E%EF%BC%8C%E5%8F%AF%E8%B0%83%E6%95%B4%20BAR%20%E4%B8%8B%20BAR0%20%E7%9A%84%E6%9C%80%E5%A4%A7%E6%94%AF%E6%8C%81%E5%A4%A7%E5%B0%8F%E5%8F%AA%E6%9C%89%204GB%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%208GB%E3%80%82%E6%82%A8%E7%9A%84%E6%97%A5%E5%BF%97%E5%B7%B2%E7%BB%8F%E6%B8%85%E6%A5%9A%E5%9C%B0%E8%AF%B4%E6%98%8E%E4%BA%86%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%9A%20%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3EBAR%200%EF%BC%9A%E5%BD%93%E5%89%8D%E5%A4%A7%E5%B0%8F%EF%BC%9A256MB%EF%BC%8C%E6%94%AF%E6%8C%81%EF%BC%9A256MB%20512MB%201GB%202GB%204GB%E3%80%82%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E3.%E6%AD%A3%E5%A6%82%E5%9C%A8%E6%9C%89%E5%85%B3%20amd-gfx%20%E7%9A%84%E8%AE%A8%E8%AE%BA%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E9%82%A3%E6%A0%B7%EF%BC%8Camdgpu%20%E5%B0%9D%E8%AF%95%E5%B0%86%20GPU%20%E7%9A%84%20BAR0%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%B0%BD%E5%8F%AF%E8%83%BD%E5%A4%A7%E7%9A%84%E5%80%BC%EF%BC%9B%E5%A6%82%E6%9E%9C%E7%A9%BA%E9%97%B4%E4%B8%8D%E8%B6%B3%E6%88%96%E8%AE%BE%E5%A4%87%E4%B8%8D%E6%94%AF%E6%8C%81%E6%9B%B4%E5%A4%A7%E7%9A%84%E5%B0%BA%E5%AF%B8%EF%BC%8C%E5%88%99%E4%BC%9A%E9%80%80%E7%BC%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Flists.freedesktop.org%2Farchives%2Famd-gfx%2F2020-December%2F057339.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Flists.freedesktop.org%2Farchives%2Famd-gfx%2F2020-December%2F057339.html%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E5%BD%93%E5%89%8D%E6%97%A5%E5%BF%97%EF%BC%8C%E5%B9%B6%E4%B8%8D%E6%98%AF%20amdgpu%20%E4%B8%8D%E6%83%B3%E6%89%A9%E5%B1%95%EF%BC%8C%E8%80%8C%E6%98%AF%20RC%20%E4%B9%8B%E5%90%8E%E7%9A%84%2064%20%E4%BD%8D%E8%BF%9E%E7%BB%AD%E5%8F%AF%E9%A2%84%E5%8F%96%E7%A9%BA%E9%97%B4%E4%B8%8D%E8%B6%B3%E3%80%81%E4%B8%8D%E8%BF%9E%E7%BB%AD%E6%88%96%E4%B8%8D%E7%AC%A6%E5%90%88%E5%AF%B9%E9%BD%90%E8%A6%81%E6%B1%82%E3%80%82%20%E5%BD%93%E5%89%8D%E7%AA%97%E5%8F%A3%E7%9A%84%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%E6%98%AF%200x10000000%EF%BC%88PCI%20%E7%AB%AF%EF%BC%89%EF%BC%8C%E8%BF%99%E4%B8%8D%E6%98%AF%204GB%20%E8%87%AA%E7%84%B6%E5%AF%B9%E9%BD%90%E8%BE%B9%E7%95%8C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2357506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GFX%20Ring%20Test%20Failure%20on%20AMDGPU(E9171)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E7%A7%8D%E9%99%90%E5%88%B6%E6%98%AF%E5%8F%AA%E9%92%88%E5%AF%B9%20i.MX95%20%E8%BF%98%E6%98%AF%E4%B9%9F%E9%92%88%E5%AF%B9%20T2080%20%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%9F%E8%AF%B7%E7%A1%AE%E8%AE%A4%20T2080%20%E5%A4%84%E7%90%86%E5%99%A8%E5%8F%AF%E4%BB%A5%E5%88%86%E9%85%8D%E5%A4%9A%E5%B0%91%E5%9C%B0%E5%9D%80%E7%A9%BA%E9%97%B4%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EGanesh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GFX%20Ring%20Test%20Failure%20on%20AMDGPU(E9171)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%20i.MX95%20%E4%B8%BB%E6%9D%BF%E4%BD%BF%E7%94%A8%20E9171%20GPU%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%E8%BF%98%E6%9C%89%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%20GFX%20Ring%20%E6%B5%8B%E8%AF%95%E4%BC%9A%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%9C%89%E4%BB%80%E4%B9%88%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3CBR%20%2F%3EGanesh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GFX%20Ring%20Test%20Failure%20on%20AMDGPU(E9171)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262041%22%20target%3D%22_blank%22%3E%40Ganesh3955%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E9%87%8C%E7%89%B9%E6%8C%87%20i.MX95%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
